-   -   building a deck above a work area in my barn (http://www.diychatroom.com/f19/building-deck-above-work-area-my-barn-163126/)
Larion Swartzen 11-12-2012 06:21 PM
If I use 6 x 6 treated posts 20' long as beams and have them spaced 12' apart. Can I use 2 x 12 joists at 16" spacing to build a deck? If so how much weight would the floor support pr sq foot and would I need to use posts in the center of each beam?
GBrackins 11-12-2012 08:52 PM
Welcome to the forum!
I'm not following .... 20' long beam and 12' spacing of post seems you'd come up about 4' short on your beam
I'd suggest checkin' out the American Wood Council's "Prescriptive Residential Wood Deck Construction Guide" based upon the requirements of the 2009 International Residential Code (this code may or may not apply to your area). it will give you the required size of beams and joists based upon their spans, and how to build a code compliant deck.
Hope this helps ...
robertcdf 11-12-2012 09:23 PM
No, you cannot use 6x6 for beams in most cases.
Joe Carola 11-13-2012 06:01 AM
Hope this helps ...
He's saying that he wants to use 20' 6x6's 12' apart for girders perpendicular to 2x12's 16" centers.
mae-ling 11-13-2012 10:16 AM
multiple (4) 2x6's or whatever actually make a stronger beam then a single 6x6.
Is headroom an issue?
Tell use the size of the area you want to build this deck. also the intended use.
If your going wall to wall ( or support) your going to need some large beams or engineered ones.
