Building A Deck. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-26-2010, 10:59 PM   #1
building a deck.
I'm building a deck with a patio below. i'm using concreting cinder blocks as the columns or posts(2 blocks side by side, filled with concrete and rebar). The decking will be about 8 1/2' above the patio. is there any tricks to cantilevering the cinder blocks around the beam??? I'd like the columns to continue past the beam and support the railing.
easygoin is offline   Reply With Quote
Old 08-27-2010, 08:09 AM   #2
kwikfishron's Avatar
Rewards Points: 176
Why wouldn’t you use wood?
You can wrap your post in just about anything if there is some kind of look you’re trying to achieve.
kwikfishron is online now   Reply With Quote
Old 08-27-2010, 09:12 AM   #3
Chicago, IL
Michael Thomas's Avatar
If you are located someplace that requires a permit to build the deck, and you are using a "non-standard" method of deck support, the entire structure likely will be required to be designed by an architect, structural engineer, or other appropriate licensed design professional.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 08-27-2010, 10:25 AM   #4
Rewards Points: 558
^^^^ what he said ^^^
epson is offline   Reply With Quote
Old 08-27-2010, 01:19 PM   #5
Old School
Willie T's Avatar
Here's a thought:
You could add cut 6" blocks to make the hole higher if you needed. (As shown in the lower pic) Tar paper can be used between block courses to contain the grout lift.
I've shown this column with two-cell blocks. If you used three cell blocks instead, you would not only have an easier time of controlling the grout lift, but you would also have that center cell filled with grout to submerge your beam anchors into. Those could be nothing more than long lag bolts protruding down from the bottom of the beam.
BTW, this is fairly common construction here in Florida. Our hurricanes aren't kind to mere wooden posts.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
Michael Thomas (08-27-2010)
building codes & Deck Rails with 3/4" aluminum spindles mroyten Building & Construction 8 09-20-2010 09:13 AM
Building Shed roof over deck f8lyer8s Building & Construction 3 07-17-2010 12:13 PM
Building Deck on top of Roof wombosi Building & Construction 0 10-26-2008 05:26 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 12:05 PM
