Building A Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-23-2013, 06:18 PM   #1
building a deck
I am building a roof over my deck and I was planning on using lag screws to secure the rim board to the house and the inspector said I had to use a different type of screws he said they look like lag screws but had a star shape head and suppose to be stronger then lags. I was wondering if any body could help me out and knew what these are called? Thanks in advance for any help or input.
POWER STROKE is offline   Reply With Quote
Old 04-23-2013, 08:34 PM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 660
Send a message via Skype™ to AndyGump
He is probably referring to "LedgerLocks"
HERE is a link.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 04-23-2013, 08:44 PM   #3
Rewards Points: 12,802
Got a picture of how your trying to attach this roof?
There's a whole bunch of ways this can be done wrong and have the roof leak.
Never once had I had an inspector suggest using those screws instead of through bolts or lags, so I like to see what he's talking about.
mae-ling (04-23-2013)
Old 04-23-2013, 10:31 PM   #4
HERE is a link.
Andy.
Thanks for you reply and help
Old 04-28-2013, 08:54 AM   #5
Bum, Bump, Bump
Old 04-28-2013, 09:30 AM   #6
Rewards Points: 528
You received your answer already, what more do you want to know?
Ledger lock is the correct answer.
framer52 is offline   Reply With Quote
The Following User Says Thank You to framer52 For This Useful Post:
robertcdf (04-28-2013)
Old 04-28-2013, 04:56 PM   #7
robertcdf's Avatar
Want me to say it too?
Here use these
robertcdf is offline   Reply With Quote
Building rooftop deck dwt Building & Construction 4 07-22-2011 04:51 PM
Building stairs from main deck to upper deck maj0819 Building & Construction 2 07-14-2011 09:04 AM
Building Deck on top of Roof wombosi Building & Construction 0 10-26-2008 05:26 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 12:05 PM
