Building Concrete Steps Cinder Block Frame? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-09-2010, 05:59 PM   #1
Rewards Points: 150
building concrete steps cinder block frame?
i just bought a house that needs four steps in the front to the porch. there is a frame already made out of cinder blocks and a pile of gravel in the middle. i was just thinking of putting some wood risers in front and pouring in cement, but then the cinder block frame will be open on top. is there a better way to do it? should i just make wood stairs so the treads will cover the cinder block holes?
thanks for any help.
drewhart is offline   Reply With Quote
Old 06-10-2010, 09:43 AM   #2
Rewards Points: 150
now i am thinking i will run a piece or two or rebar all the way across going into the cinder through a hole i am about to drill. that should help hold the whole thing together right? or is that not necessary? i will pour concrete into the cinder block too.
Old 06-10-2010, 01:48 PM   #3
Old School
Willie T's Avatar
This thread might help some.
Willie T
Brick Ledge when using cinder block DaveMo Building & Construction 5 07-13-2011 09:46 AM
Tying in a 2"x4" walled-booth with a cinder block wall johnofthemount Building & Construction 3 12-19-2009 02:51 PM
Installing a new windows in cinder block foundation monsterbash Building & Construction 1 04-13-2009 07:48 AM
Concrete steps Shadowchase Building & Construction 5 07-04-2008 06:01 PM
Cinder block wall hangings shnfldr Remodeling 2 06-07-2008 08:26 AM
