Building Codes For Stairs In MA - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-19-2010, 11:29 AM   #1
Building codes for stairs in MA
Hi,
I need to build stairs in somewhat confined space. I want to be certain of current code requirements in MA before I start. I've heard there were recent (2010?) changes on this. Can somebody please explain what is the min tread depth, max riser height, min stairs width? Also, is it allowed to have a step on the landing, i.e. landing is divided by the extra step that runs diagonally? I know it was common practice on old stairs, but not sure is modern codes allow it.
Thanks in advance!
schh4 is offline   Reply With Quote
Old 07-19-2010, 11:49 AM   #2
Framing Contractor
Originally Posted by schh4 View Post
Hi,
Thanks in advance!
Call your building department and ask them and see what code they're under. This the IRC code.
http://www.qis-tx.com/documents/stai...guidelines.pdf
Joe Carola
Joe Carola is offline   Reply With Quote
Old 07-19-2010, 08:29 PM   #3
Registered User
Rewards Points: 5,204
Joe's correct, local first. If closed now, check with your State for the latest code revision. Here's another one, only two years old: http://bulk.resource.org/codes.gov/
Be safe, Gary
Tags
codes , mass , stairs
Building codes 68MHJCs Building & Construction 6 12-27-2009 01:20 PM
Building codes in NC?? organick General DIY Discussions 9 10-10-2009 10:35 PM
Need help from someone familiar with sound transmission building codes PLEASE jessica3660 General DIY Discussions 4 08-25-2009 06:56 PM
Where to find building codes? nimblemotors General DIY Discussions 5 06-27-2008 08:15 AM
Building codes? Keener General DIY Discussions 2 11-10-2007 08:05 PM
