Building Codes & Deck Rails With 3/4" Aluminum Spindles - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-19-2010, 10:27 PM   #1
building codes & Deck Rails with 3/4" aluminum spindles
Two questions:
1. where would I find my region's building codes for decks?
2. I'm redoing the rails on my deck and plan on using 3/4" aluminum spindles, what is the typical amount of rails per foot or how many inches between each? I'm trying to figure out how many I should purchase.
mroyten is offline   Reply With Quote
Old 08-20-2010, 08:51 AM   #2
jlhaslip's Avatar
Rewards Points: 2,820
where are you?
the code here is 4" (100mm) max opening between adjacent spindle faces.
Doesn't matter the width of the spindles, only the opening size.
And there is a 200 pound thrust factor. Can a 200 pound person lean against it without weakening the rail?
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 08-20-2010, 08:59 AM   #3
Old School
Willie T's Avatar
We're 250# here, so be sure to check with your municipality's Building Department. (I s'poze we gots mo fat folk here 'bouts.)
Willie T
Old 08-20-2010, 09:44 AM   #4
Rewards Points: 558
Check with your local municipalities building department. They will give you all the spec’s you need to build a deck in your area. In my area they hand out preliminary sample drawings/details as a guide. As per the spacing, it should be 4’’ between the pickets and if your deck is higher than 4’-0 the railing should be 42’’ high with the hand railing going down the stairs at 36’’ in height or you can match your railing height if you want.
epson is offline   Reply With Quote
Old 08-20-2010, 04:39 PM   #5
Stairguy
Millertyme's Avatar
Rewards Points: 508
linear feet of handrail in inches and divide by 4= number of balusters
Millertyme is offline   Reply With Quote
Old 08-20-2010, 04:47 PM   #6
kwikfishron's Avatar
Rewards Points: 826
Did you subtract for post?
kwikfishron is online now   Reply With Quote
Old 08-20-2010, 05:10 PM   #7
Old School
Willie T's Avatar
And for baluster widths (if a long enough run)
Willie T
Old 08-20-2010, 07:11 PM   #8
Stairguy
Millertyme's Avatar
Rewards Points: 508
you do not need to subtract baluster width as they are measured center to center. unless the balusters are really large, then you may go 5 or 6 on center. For most jobs 4" in fine. You can take the measurement in between post if you want then divide that by 4, but its always good to have a couple of extra balusters. Or you just tighten up your spacing.
Old 09-20-2010, 08:13 AM   #9
Spacing between balusters typically needs to be less than 4 inches to meet code (not a gap of 4"). I usually choose 3.75" side to side (of 3/4 in aluminum baluster)
Deckmaster is offline   Reply With Quote
Tags
deck , rails , spindles
Building new deck and screened in Gazebo - Wood or Composite? Todd1 Building & Construction 10 11-05-2010 11:24 AM
Building deck rails n0c7 Building & Construction 7 08-05-2010 11:35 PM
Building Shed roof over deck f8lyer8s Building & Construction 3 07-17-2010 11:13 AM
Need help with deck building l0gik Building & Construction 15 07-07-2010 07:39 AM
Building codes? Keener General DIY Discussions 2 11-10-2007 07:05 PM
