Old 12-26-2009, 08:52 PM   #1
Building codes
Where would I be able to find building codes at? All residential all areas PLumbing Electric etc.. Is there a web site I can find this info?
68MHJCs is offline   Reply With Quote
Old 12-26-2009, 09:36 PM   #2
Moderator
Building codes
http://bulk.resource.org/codes.gov/
Be safe, Gary
Clothes taking longer to dry?
Old 12-26-2009, 09:51 PM   #3
Building codes
Not the actual code..What the code is. EX a outlet must be how many inches from the floor. Proper insulation for certain areas, proper way to run plumbing.
Old 12-26-2009, 11:54 PM   #4
Moderator
Building codes
Do you want to know the minimum building code that County's base their amendments on? This Code Check Building, Canada is the same exact one used in the U.S., just 5 years old: FREE download, 30 pages: http://rapidlibrary.com/index.php?q=...code+of+canada
Be safe, Gary
Old 12-27-2009, 12:21 AM   #5
Building codes
Is there a trick to downloading the files? It says enter the code to download...so i do...and all it does is bring up a new page asking you to enter the same code over and over and over
TitaniumVT is offline   Reply With Quote
Old 12-27-2009, 07:32 AM   #6
Building codes
Codes vary all over the country. Localities modify basic codes to suit themselves, so what you read on the net may not apply to your area. Check local building department.
Old 12-27-2009, 01:20 PM   #7
Moderator
Building codes
Sorry about that. Apparently they stopped the free download sometime after I got mine a year ago.
" EX a outlet must be how many inches from the floor." ----- depends on local code amendments.
"Proper insulation for certain areas" -- If in the U.S., D.O.E. : http://www.ornl.gov/sci/roofs+walls/...on/ins_16.html
" proper way to run plumbing." ----- I refer to books for what I question: http://books.google.com/books?q=inst...ell=1&oi=spell
Be safe, Gary
Building codes in NC?? organick General Discussion 9 10-10-2009 10:35 PM
Need help from someone familiar with sound transmission building codes PLEASE jessica3660 General Discussion 4 08-25-2009 06:56 PM
South FL Building Codes Matty16 Building & Construction 8 08-03-2008 07:25 AM
Where to find building codes? nimblemotors General Discussion 5 06-27-2008 08:15 AM
Building codes? Keener General Discussion 2 11-10-2007 08:05 PM
