Building Code Violation - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-21-2008, 06:39 AM   #16
conc repr & dec conc
Send a message via AIM to dec-conc-artisan Send a message via Yahoo to dec-conc-artisan
long story short,,,
if you've signed the offer to buy & paid any earnest $$$, you're stuck ! ! !,,, you can, of course, not complete the transaction but you'd be liable for damages,,, this item doesn't pass the ' smell ' test.
all comes down to this - do you want the house or not ? ? ?
dec-conc-artisan is offline   Reply With Quote
Old 03-22-2008, 03:32 PM   #17
Hi everyone
Ok, to clarify the background and your questions..
I gave a bid on a house built 2001 and the only contingency I had was the home inspection. The inspector found a bulge on the exterior outside wall together with icicles.
Pics can be found here:
http://virginlake.bravehost.com/content/DSC_3713_large.html
http://virginlake.bravehost.com/content/DSC_3915_large.html
When inspecting inside the house this was found
http://virginlake.bravehost.com/content/DSC_3875_large.html
Picture taken from the opening of the jacuzzi and obviously no vapor barrier to the external wall.
There is a code that is in place since 1999
http://www.legis.state.wi.us/rsb/code/comm/comm022.pdf
Comm 22.22 Vapor retarders
(2) Framed Assemblies. In all framed walls,floors and ceilings, the vapor retarder shall be installed on the warm side of the thermal insulation. The vapor retarder shall cover the exposed insulation and the interior face of studs, joists and rafters. No vapor retarder is required in the box sill.
Also the inspector found that the radon level was 15,9 pCi/L, shall be less then 4.0
The inspector wrote up the radon level and the bulge/icicles as a defect.
The seller had the builder of the house to come and see the bulge.
This is his report:
"XX contacted me a few weeks ago stating that there was an issues on a house he was selling that I had built, and be asked if I would check it out.
I contacted the owner and headed over the next day. I was told the inspector had found a bulge in the wall behind tbe whirlpool tub and there wasn't any vapor barrier behind the tub and the inspector thought that the bulge resulted from moisture coming from that area around the tub from the lack of vapor barrier. I explained to xx that it is very conmmon to find whirlpool tubs with no vapor barrier behind them because they are in it self a vapor barrier.
Build a house goes as following but not from the start; Foundation, framing, roofing, heating, plumbing, electrical. insulation, vapor barrier.
The plumbers install the tubs prior to the insulatoin so the plumbers actually install the insulation behind the tubs they install. My plumber that works for numerous other builders doesn't not install vapor barrier. Once the tub is installed and the door is fastened the tub creates its own vapor barier because the tub is made out of fiberglass and is waterproof.
Prior to installing the insulation, the builder needs to call for a rough inspections which does include all the plumbers work. After this inspection the insulator are brought in to install the insulation and install the vapor barrier. The inspector signed off and passed all work at xx.
Findings on the roof
Once I jumped on the roof I noticed that the bulge was at least 4 feet away to the south of were the tub was placed in the house and there was also a closet that separated the two concerns .
I started pulling of the siding from above the truss line and instantly noticed what I thought the problem was. With the record snow and weather we are having snow had
built blown up through the siding and had built up behind the siding in the area in question right above the peak of the garage. The snow was melting and dripping onto the wall sheeting/OBS. the one sheet that was wet had expanded. I popped the siding off in the area that bad been affected and let it dry over the warm weekend we had two weeks ago. I also cut a relief in it centered on a stud and nailed and screwed it back in place, and re fastened all the sidings the bulge is now gone.
In my professional options I feel that the issue was from the snow, not the area under the
bot tub, and to be honest, I can't believe the inspector even thought that was the case.,
yy"
I was notified by the seller that everything now was ok. As I don't think that snow could cause the bulge and the icicles I said that I didn't believe that the fix was adequate and would like to have an independant inspection. After some discussions with the attorneys that now was involved I got the ok to do a non invasive inspection, which I had to pay for.
fetzo is offline   Reply With Quote
Old 03-22-2008, 03:33 PM   #18
[FONT='Arial','sans-serif']Here is the independent inspectors report[/FONT]
[FONT='Arial','sans-serif']"[/FONT]
[FONT='Arial','sans-serif']The subject of this report will be named the ‘ice event’[/FONT]
[FONT='Arial','sans-serif']Reason for the inspection and the report:[/FONT]
[FONT='Arial','sans-serif']1. Attempt to verify that the work performed by the seller was done right.[/FONT]
[FONT='Arial','sans-serif']2. The cause of the ‘ice event’ needed to be determined so corrective action can be taken if necessary so it doesn’t happen again.[/FONT]
[FONT='Arial','sans-serif']About the ‘type’ of inspection:[/FONT]
[FONT='Arial','sans-serif']The inspection was limited to non-invasive techniques. I used a thermal imaging device to look for temperature differences on the surface of the drywall that might indicate water within the wall, and I used visual inspection.[/FONT]
[FONT='Arial','sans-serif']What was found:[/FONT]
[FONT='Arial','sans-serif']Thermal imaging did not detect any temperature differences of the interior surface of the drywall that might be interpreted as water in the drywall or water in the wall cavity.[/FONT]
[FONT='Arial','sans-serif']Visual inspection of the attic floor, near the exit of the dryer vent, showed evidence that a little water had been there (ponding), but the majority of the current wetting was on the gable sheathing.[/FONT]
[FONT='Arial','sans-serif']Visual inspection of the surface of the wall sheathing, (the OSB) near where the ‘ice event’ happened, visible from the garage attic, showed no evidence of water. Visual inspection found a broken dryer vent in the attic. The aluminum duct of the dryer vent was detached from the plastic flapper assembly.[/FONT]
[FONT='Arial','sans-serif']Results of the inspection:[/FONT]
[FONT='Arial','sans-serif']Encouraging, but not conclusive.[/FONT]
[FONT='Arial','sans-serif']1. Only invasive inspection of the area can be conclusive to determine whether or not there[/FONT]
[FONT='Arial','sans-serif']is moisture in the wall cavity(s).[/FONT]
[FONT='Arial','sans-serif']2. I am fairly confident of my conclusion as to the cause of the ‘ice event’, but conditions to[/FONT]
[FONT='Arial','sans-serif']duplicate the event will not happen again until next winter.[/FONT]
[FONT='Arial','sans-serif']2[/FONT]
[FONT='Arial','sans-serif']Inspectors conclusions:[/FONT]
[FONT='Arial','sans-serif']All clues indicate the cause of the ‘ice event’ is a faulty (broken and detached) dryer vent.[/FONT]
[FONT='Arial','sans-serif']Why did the dryer vent break?[/FONT]
[FONT='Arial','sans-serif']1. Lack of maintenance due to inaccessibility, and[/FONT]
[FONT='Arial','sans-serif']2. Buildup of ice due to lack of maintenance[/FONT]
[FONT='Arial','sans-serif']Here’s how this happens:[/FONT]
[FONT='Arial','sans-serif']When the temperature outside is colder than the temperature inside, small quantities of warm moist (relatively) air exit the building due to the ‘stack’ effect. One location where this will occur is through the second floor clothes dryer duct/vent, due to it’s location high in the structure. Think of the second floor dryer vent ductwork as a little chimney.[/FONT]
[FONT='Arial','sans-serif']As this trickle of warm air leaving the building, via the ‘little chimney’, reaches the cold surface of the vent flappers on the exterior wall, the moisture (water vapor) in the air will condense. If it is cold enough, the condensation will freeze. As more air passes, ice will continue to build until the hole allowing the air to pass is closed. So long as the little flappers are shut, the quantity of ice will be small, because it won’t take very much ice to freeze the flappers shut. Once the vent is frozen shut, the air will cease to flow out and the build-up of ice will stop.[/FONT]
[FONT='Arial','sans-serif']Now, however, let’s say one or more of the little flappers is stuck open because of lint, particularly the upper flapper. The lint is there because you can’t easily get to the vent to clean it, and because the vent is clearly out of sight and out of mind. The build-up of ice would be quite significant. Inches of ice could build in an effort to close the 4” diameter hole as air continued to flow across the top of the ice. This much ice would be significant enough to break things due to expansion, or hold the duct frozen in place while the plastic vent expanded from warmth when the sun hit it. This much ice would be significant enough to pour considerable amounts water down the siding when the dryer was turned on and the warm air from the dryer melted the ice.[/FONT]
[FONT='Arial','sans-serif']It must be assumed the dryer vent was not broken when it was installed, because contractors don’t build broken houses, so how did it break?[/FONT]
[FONT='Arial','sans-serif']The only plausible explanation is contributing factors due to the build-up of ice.[/FONT]
[FONT='Arial','sans-serif']If the dryer vent is repaired to it’s original design configuration, it must be assumed the same thing will happen again because:[/FONT]
[FONT='Arial','sans-serif']1. It is still not in a readily accessible area to perform maintenance, and[/FONT]
[FONT='Arial','sans-serif']2. It is still in a location that is very far out of sight and out of mind until something bad happens.[/FONT]
[FONT='Arial','sans-serif']There is one other factor in the equation. Air pressure in the duct created due to a vent that is frozen shut. Pressure would certainly build, but I do not think the air pressure created by the dryer fan alone would be enough to ‘blow apart’ the dryer vent. However, the air pressure wouldn’t help the situation either, and it cannot be ruled out as a contributing factor."[/FONT]
[FONT='Arial','sans-serif']At this point I didn't wanna pursue buying the house, how would I know that there are no issues with the attic? My insurance company will not pay for any mold issues as the house does not have a vapor barier, in this cause not caused by this, but I'm sure they will blame on it when it comes to pay out money.[/FONT]
[FONT='Arial','sans-serif']I hope this gives you a better understanding of what's going on.[/FONT]
[FONT='Arial','sans-serif'][/FONT]
[FONT='Arial','sans-serif']Thanks[/FONT]
[FONT='Arial','sans-serif']Erik[/FONT]
Old 03-22-2008, 03:42 PM   #19
"The subject of this report will be named the ‘ice event’
What was found:
1. Only invasive inspection of the area can be conclusive to determine whether or not there is moisture in the wall cavity(s).
2. I am fairly confident of my conclusion as to the cause of the ‘ice event’, but conditions to duplicate the event will not happen again until next winter. Inspectors conclusions:
1. It is still not in a readily accessible area to perform maintenance, and It is still in a location that is very far out of sight and out of mind until something bad happens.
Erik
Building to code? jbmike7 Building & Construction 2 03-03-2008 12:15 AM
code violation? krw1957 Electrical 6 12-11-2007 07:16 AM
national building code book smallcrpt General DIY Discussions 2 11-13-2007 08:09 AM
sewage building code for home owners aokss Plumbing 9 09-11-2006 07:37 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 07:35 PM
