Building Chases Around Waste Stacks - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-07-2010, 05:41 PM   #1
Rewards Points: 209
Building chases around waste stacks
I'm getting ready to insulate the part of my basement where all 5 waste stacks run. Unfortunately, all five are on the perimeter wall, each approx 3-4 inches from the block wall. The stacks are all copper, installed in 1951. Some have clean-out plugs at the bottom, some do not.
My plan for the walls there is to place 1 inch foam panels against the block walls, then stud walls with fiberglass, then sheetrock. But the five waste stacks will either need to be skipped, or chased, correct? I'm not aware of any other way to deal with them.
Does anyone have advice on how much clearance to give each stack? Or whether to leave an opening in the chase for the clean-outs? I'm assuming if any work ever needed to be done on a stack, its chase would have to be demo'd anyway.
Any advice appreciated.
dave11 is offline   Reply With Quote
Old 06-08-2010, 02:41 PM   #2
XPS insulation between the stack and the block wall would be good.
Clean outs should have an access door to allow for maintenance.
Advice on building a backyard studio/office? johnnyb10 Building & Construction 11 12-03-2011 11:43 PM
NEC uses building size?????? hhiibel Electrical 14 08-08-2008 12:19 PM
Building a movable garden shed/greenhouse gardener Building & Construction 1 06-13-2008 04:47 PM
A steel building that doesn't look like a steel building? MMW Building & Construction 1 06-11-2007 04:24 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 06:35 PM
