Building A Cedar Pergola - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-07-2010, 12:42 PM   #1
Building a Cedar Pergola
Should I place the Cedar post 2 ft in ground or should I use collars on top of the concrete and have the post on top on the concrete. I'm being told by friends that Cedat will rot over time if it is in concrete.
Nupe70 is offline   Reply With Quote
Old 06-07-2010, 12:50 PM   #2
Depending upon the conditions/installation cedar can rot in as little as 10 years, maybe less
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Nupe70 (06-07-2010)
Old 06-07-2010, 05:55 PM   #3
Rewards Points: 5,336
All wood will rot quicker in ground vs. on top. Step it off the soil with the standoffs.
Ron
Pergola - can you believe what the building inspector told me Italgrl Building & Construction 35 09-05-2014 12:00 PM
building a pergola december45 Carpentry 1 08-05-2009 03:11 PM
Building a Large Pergola CCE1876 Building & Construction 1 04-28-2009 02:19 PM
Building Cabin.. Can I use cedar deck 5/4 radiusx6 on floors? Going Nuts Flooring 1 07-19-2006 06:37 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
