Building Carport - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-11-2009, 06:24 PM   #1
Question
Building carport
I'm planning on building a one-car carport (12'x20') over an existing concrete parking pad. I would like to know if the 4"x4" support post I'm planning on using would provide enough structural strength if the post are anchored directly to the existing concrete. I plan on anchoring the post using Simpson anchors or something similar. We do have some pretty strong winds here in Ohio sometimes and the snow fall can get pretty deep at times. Let me know what you think.
Thanks.
Chadwell
Chadwell is offline   Reply With Quote
Old 07-11-2009, 07:07 PM   #2
Yes, Simpson anchors would be fine. I work for a large kitset building manufacturer and this is one of the fixing options we use for our carports.
Make sure that the bolts are at least 100mm away (4 inch) from the edge of the concrete. Also you will need some braces running from the post diagonally up to the rafters - two per post. 700mm (30 inch long braces). Otherwise the carport will sway.
However there is no doubt that concreting the posts directly into the ground is the strongest fixing method. A 12 in x 12 in hole 48 inch deep would be sufficient
superoman is offline   Reply With Quote
Old 07-11-2009, 07:11 PM   #3
How thick is the concrete?
Will this be out in the open or attached to one side of the house?
Old 07-11-2009, 07:12 PM   #4
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
Also look into a way to prevent moisture from working up the post from the concrete. Not sure what is the best way, I'm guessing some kind of small plastic around the bottom and sides of the post a few inches high may do. There may be a better way that I'm not aware of as well.
Just saying as I noticed my 3 support beams for my house are resting on a concrete footing but I can see a bit of rotting on the edges. Nothing major and the house is fairly old, but something I will need to look at eventually.
Old 07-11-2009, 07:36 PM   #5
The concrete is 4", and it will be a free standing structure. We live in a wooded area which gives it some protection from strong winds.
Old 07-11-2009, 09:33 PM   #6
Rewards Points: 5,336
The structure would need a perimeter foundation/footing system to install the weight of a carport on top. Minimally, the footings would be under the posts.
Do you know how the concrete pad was constructed?
Ron
Tags
anchoring post , carport
Building Attached Carport MikeVila Building & Construction 4 01-12-2009 04:23 PM
NEC uses building size?????? hhiibel Electrical 14 08-08-2008 12:19 PM
conc slab inside/under a enclosed metal carport blthomas Building & Construction 3 02-01-2008 09:18 AM
International building code and permits rforsha Building & Construction 4 08-28-2006 06:35 PM
