Building Bulkhead On Side Of House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-09-2011, 10:13 PM   #1
Building bulkhead on side of house
My house was built with an unfinished bonus room that I'd like to finish soon. However, when the house was built, they ran the HVAC trunk and water heater exhaust flue haphazardly through the floor, so if I bulkhead them in, it would take a good five to ten feet of floor space.
I'd like to build the bulkhead (or have it built) up the side of my house from the crawlspace area to the attic and route that HVAC trunk and the water heater exhaust through it....but, I have no idea where to start to even get educated about this. I know the water heater duct has to be at least 6 inches away from combustibles, but are there any other considerations I should keep in mind? Does anyone have a good reference source I could check out? I already contacted my local building codes department, but they weren't much help. Is this even a realistic possibility?
I appreciate any help anyone can offer.
oatlord is offline   Reply With Quote
Old 01-09-2011, 10:16 PM   #2
Rewards Points: 558
Call your HVAC guy they will be more able to assess your requirements.
epson is offline   Reply With Quote
Old 01-10-2011, 02:24 AM   #3
Actually I did talk to them. They just said build a bulkhead in the bonus room, but I'd like free up all the floor space if possible. Running the duct through a different path seems like it wouldn't be a problem, though. Just cut in the crawlspace and run new stuff down the bulkhead. I'm just not sure where to start on the construction of the bulkhead as well any possible codes issues with running an exhaust vent and HVAC trunk so close together.
Old 01-10-2011, 08:24 AM   #4
Rewards Points: 558
The HVAC guys are the ones who will design a new path for your duct work as they will do a new heat and loss calculation. The more elbows you put in your ducts the more heat you will lose. Iím not a HVAC guy but I am on construction sites a lot and I do talk to a lot of peopleÖ
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
House 2 years, 5 months old now has huge bulge on side of house. Dee Johnson Building & Construction 16 10-09-2010 07:28 PM
where to begin on building a house? hunniebugg Building & Construction 26 06-06-2008 10:09 AM
building my own house mikeydude Building & Construction 7 11-09-2005 04:10 PM
