-   -   Building Boxes around Vents/Pipes in Basement (http://www.diychatroom.com/f19/building-boxes-around-vents-pipes-basement-2153/)
H Thomas 03-30-2006 07:43 AM
We are putting drywall on the ceiling in our basement. Most of the basement will be no problem, however there is a section where there are a lot of mechanicals runing that we need to "box in". This area is at the least two ducts wide, and there is one area where a diagonal drain pipe make it even more challenging. Any suggestions for the best way to tackle this? I had read about using OSB and creating mini "walls" on either side of the area to be boxed and then running 2/4s underneath the vents. Any experience with this? What is the longest span this would work on? Any help would be very much appreciated!!
Taipans 03-27-2008 07:10 AM
I know its been a few years and figured by now your done with everything. I'm in the middle of doing this right now. Yes OSB board is a good way to do longer spans and keep things rigid. Many people have suggested always using OSB then covering with drywall on "boxed-in" areas but its not really needed. I used it on areas over 16 inches to make it rigid, then just made sure where the drywall went alone I had cross members inplace. :thumbsup:
Sure your an expert on this by now, if you have any pictures of your old project post them up!
kcdave 03-28-2008 10:55 AM
Thats what I did. I had to cover the main duct and a beam, span was about 3' and came down about 12". I cut a sheet of OSB 12" in 8' lengths and nailed a 2x3 at the top and bottom. The top 2x3 was nailed edge side into the OSB, the bottom was nailed with the side into the OSB. The top was then nailed into the floor joist and the bottoms were tied together with another 2x3. I did another 10' span that dropped down about 2 feet the same way using 2x4's. About every 3-4' I placed a 2x4 from the bottom spans up to a floor joist for support. But, there are lots of ways to do this (and cheaper). You really don't need the OSB and I have seen lots of boxing done with just 2x2's.
