Building A Beam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-18-2013, 04:34 PM   #1
Building a beam
Using 2 2x10's for deck beam is there a specific nailing pattern I would need to use? My google searches are turning up too many different options.
Also would 10d nails work as the beam will only be 3'' wide?
Thanks,
dabeast is offline   Reply With Quote
Old 10-18-2013, 04:54 PM   #2
cortell's Avatar
Rewards Points: 504
Thanks,
Yes. 10d is what you want. If you're using a nailer, drive them at a *very slight* angle so that the tip of overdriven nails don't protrude and become a hazard.
Commonly prescribed pattern is two nails at each end then one 8" OC at the top and bottom, staggered. That said, many framers just do a vertical run of three nails 24" OC or so.
cortell is offline   Reply With Quote
Old 10-18-2013, 10:02 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,264
well first off 2 2x10`s isnt a beam you need 3 ply. as for nailing rows of 4 spikes 16" O.C is standard practice
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
ben's plumbing (10-20-2013)
Old 10-18-2013, 10:11 PM   #4
GBrackins's Avatar
Rewards Points: 2,108
is the beam top loaded or side loaded? that determines the proper lamination of the plies.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 10-18-2013, 11:55 PM   #5
Side loaded I guess? It is for a deck and will be notched into a 6x6.
Old 10-19-2013, 07:20 AM   #6
cortell's Avatar
Rewards Points: 504
Really? Someone better tell the AWC and IRC to update their beam tables.
BTW, dabeast, the answer to your question is on page 6 (figure 4, Beam Assembly Details)
http://www.awc.org/publications/dca/dca6/dca6-09.pdf
Old 10-19-2013, 07:26 AM   #7
GBrackins's Avatar
if the joists are attached to the side of the beam then I'd use screws or bolts. as cortell said above check out the American Wood Council's "Prescriptive Residential Wood Deck Construction Guide," which is based upon the code requirements of the 2009 International Residential Code.
you may want to review this guide to ensure proper design of your deck.
Good luck!
Gary
The Following User Says Thank You to GBrackins For This Useful Post:
cortell (10-19-2013)
Old 10-19-2013, 10:55 PM   #8
So the deck will be 8' deep 16' wide I have a total of 3 posts per beam (every 8') 2 2x10x16 will build each beam (free standing deck).
I will be using joist hangers to flush mount the joists to the top of the beam (space issues).
What i'm looking for is the best way to join the 2 2x10x16's together. Could I nail one side in a W pattern as show in the deck guide posted above and then flip it over and do it on the other side? Or should I use screws and/or bolts?
Old 10-19-2013, 11:45 PM   #9
GBrackins's Avatar
screws or bolts for side loaded beam, you don't want any lateral movement to separate the plies.
Gary
Old 10-20-2013, 08:28 AM   #10
AHH, SPANS!!!
Rewards Points: 1,166
for a beam I nail a vertical 5 nail pattern every 16" and then flip around and do the same from the other side except start the nail pattern centered between your first rows so if you were to look down on the beam the nail rows would be spaced 8" apart.
hand drive is offline   Reply With Quote
Old 10-20-2013, 08:40 AM   #11
Civil Engineer
Rewards Points: 4,862
All you need to achieve with your nailing is enough resistance to develop adequate horizontal shear capacity between the two pieces making up the beam. This can be calculated (the formulas are a bit complex and I will avoid a primer on structural mechanics), or more commonly you just go with local practice. In my area, the typical approach is to start with two 10d nails on one end, about two inches from the end of the beam, and about 1-1/2 inches respectively from the top and bottom. You then nail in a staggered pattern every six inches, top and bottom, from the outer face in. My deck is built that way, and it worked out fine.
Use proper nails for PT lumber, hot dipped galvanized. You can use bolts or structurally rated screws, but why bother, nails are simple and proven.
Old 10-20-2013, 11:35 AM   #12
difference in region then, here in canada 2plys will never pass inspectino
Re: old buildings RWolff Building & Construction 157 01-19-2014 12:35 AM
Help with building a beam for the basement Bonebag Building & Construction 13 04-02-2013 10:01 PM
Building interior basement wall under laminated wood beam. PlastikSpork Building & Construction 25 07-28-2012 10:55 AM
Old Building problems jake62 Building & Construction 5 08-20-2010 08:32 AM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 01:07 PM
