Building An Attached Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-20-2009, 10:55 AM   #1
DIY = Done Right 1st Time
Building an attached garage
I have been dreaming of building a garage. I was originally thinking detached because of the simplicity of construction. But after talking with city codes I don't have enough available "accessory sq ft" to build the 24x24 garage I want. He said that I can either try to appeal the code, or I can get around the whole thing by connecting it to the house via a breezeway.
My question is when working with a new attached foundation do they literally build off my existing block (basement) foundation with a slab/block. Or is there a gap between the 2 and the new slab/block foundation will actually be build seperate but very close to the existing w/partition block wall.
With building so close I'm worried about water run off more than anything. My basement doesn't have a sump, and if drainage from our rough winters isn't considiered then I could be in for some issues down the road.
This project is starting to step outside my comfortable zone, but I'm mainly coming here to get information regarding the construction of an attached garage or breezeway. More I know, the better when it comes to hiring out for the footers/slab.
BowDown is offline   Reply With Quote
Old 05-20-2009, 03:21 PM   #2
Registered User
Rewards Points: 4,924
They will tie into your house foundation. Usually a breeze-way has a roof with gutters, what water run-off? So would the garage. Any water between the two could be collected and moved with drain tile to a sump pit.
http://www.easydigging.com/Drainage/..._soakaway.html
http://pwd.org/pdf/water_resources/c.../dry_wells.pdf
Be safe, G
Gary in WA is online now   Reply With Quote
Building Attached Carport MikeVila Building & Construction 4 01-12-2009 05:23 PM
Questions on Building apartment On top of existing detached garage nsxman2001 Building & Construction 4 12-16-2008 05:36 PM
Building a Pole Garage myself, got a few ?'s jk333 Building & Construction 4 10-16-2008 02:41 PM
Crazy Garage Extension, Building over blacktop?!?! commissure General DIY Discussions 4 09-13-2007 12:09 PM
Building garage with elevated concrete floor dmj245 Building & Construction 13 05-31-2006 05:13 AM
