Building Attached Carport
I'm just waiting for the weather to break, to start building a patio roof. In my area, snow and ground frost are a concern! I am required to under pin the posts with footings down at the 4 foot level. These will Sono tube columns, which in turn will support the 6X6 posts! Because of the 50 PSF snowload, the beam will be laminated from three, 2X10X12's. The 2X8 rafters, spanning 8 feet will be supported by a ledger board at the house end. The roof is to be sheeted with 1/2 OSB. Does this give you some ideas?
