Building An Additional Room - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-11-2006, 11:52 PM   #1
lmc's Avatar
Building an additional room
Hi, new to the forum, let me give a little background on the house it was built around the 1940's in peices at a time with different kinds of wood over the years but the house is nice and in really good shape it is three bed room one bath pier and beam foundation , there is no utility room in the house so washer and dryer are in the kitchen i would like to build a utility room on an existing back porch, and would like to know how to go about doing this, first off will it be okay to add a additional roof under the original for the room. second, would this project be under code being that it is not accually under the same roof as the house,any suggestions an ideas would be greatly appericiated.
lmc is offline   Reply With Quote
Old 09-12-2006, 09:04 PM   #2
You and I are both newbies! Congrats to both of us.
I would suggest this for starters,
Contact your local Building Officials at City Hall.
You should ask them about what is required before doing anything else. Once you confirm their requirements, which may include providing some drawings, seek a good designer/architect to look at your home. They will look at what can and cannot be done.
I am assuming you are talking about incorporating this new utility room into part of the home, using the existing roof system but adding new ceiling joists, exterior walls, right?
If you are going to hire someone to do this, contact General Contractors and ask them to submit a bid. They may provide some simple sketches/even provide drawings for a fee and provide good information as to what you can and cannot do due to existing structure.
Just some thoughts
Dougaphs is offline   Reply With Quote
Old 09-13-2006, 03:27 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I can't speak for your local building codes.
But, in my neck of the woods, you would be required to obtain a building permit for such a project.
A couple of considerations:
1.) Check out the 'supports' for that porch to see if they are adequate to hold the added weight of a washer and dryer, walls and roof load.
2.) Make sure that you will be able to creat a roof that will have the proper pitch and the ability to shed water away from the house. Example: Torrential downpour.
These are the first two things that come to my head. Number 1.) is the
primary concern.
Good Luck
- Build Well -
Adding a Additional Room christopher_45 Building & Construction 1 06-29-2007 04:23 AM
A steel building that doesn't look like a steel building? MMW Building & Construction 1 06-11-2007 04:24 PM
My kids room is cold snmhanson HVAC 5 12-20-2006 11:51 AM
International building code and permits rforsha Building & Construction 4 08-28-2006 06:35 PM
question about cleaning a boiler room Piratehart General DIY Discussions 1 02-14-2006 12:58 PM
