Building A 20' X 20' Wood Frame Garage - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-11-2011, 01:58 PM   #16
Rewards Points: 150
Put a lot of emphasis on a foundation that is perfectly square, and with L bolts sticking up and out of the concrete .You mentioned blacktop, so this idea you may not be able to do,and thats have a inch and a half lip (step) where garage door comes down. It helps to keep the cold air out,with a good seal. Have the garge door installed when you do that work in that area.
bernieb is offline   Reply With Quote
Old 03-11-2011, 02:00 PM   #17
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Originally Posted by Ron6519 View Post
I'd use LVL's.
Ron
ya beat me to it Ron............
tcleve4911 is offline   Reply With Quote
Old 03-11-2011, 02:05 PM   #18
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Good thoughts Bernie
I like to see the top of the floor 3-4" above grade with an apron transition from floor height to grade.
This really helps keep water and snow out of the garage.
You can create the apron when you patch in the asphalt since you'll be digging the existing asphalt up anyway when you set the concrete forms.
Old 03-11-2011, 03:15 PM   #19
Rewards Points: 5,336
Younger fingers.
Ron
Old 03-11-2011, 04:16 PM   #20
What can this home owner do, and what lumber should he use for the 16' opening? I'm thinking they should be 2x12's x 18 with crowns and thats with a double cripple on each side. I'd even consider a piece of flat steel between the header.....what do you think?
3 2x12's should be plenty/thats 2 in the wall and 1 inside it's the cheapest way to go or just buy 2 lvl 's 11 1/4
Stainless steel is offline   Reply With Quote
Old 03-11-2011, 04:39 PM   #21
Registered User
Rewards Points: 5,492
3-2x12's won't even work...... 1/2 of 20' span, plus o.h. is 11' x 16' dr. x 45# per sq.ft. = 7920# (30# live load-snow + 15# dead load-drywall/insulation)
3-2x12's, fb.1600, Doug fir/Larch, #2 = carry max.4700#
You'd need a 6x12, Df/L, Dense #2 ($$$) to match the 2- 1-3/4" x 11-1/4" LVL's.that will carry 9000+#. pp.#5; http://www.parr.com/PDFs/LP%20LVL%201.9E.pdf
Notice: pp.#2 = 3-1/2" beam requires 3" of bearing for 7875#, you have 8k# and need a 4x4 (9200-#) under each end for 3-1/2" bearing. Be sure to show this in your plans to the City/County for the permit.
Gary
Old 03-12-2011, 09:46 AM   #22
Rewards Points: 150
Getting very basic carpenter work here, in building one wall. Use a treated 2x4 for the bottom plate, cut so the seam, so its under a up-right 2x4, as you'll have to have a pair on edge,one green, one regular to start with, but have the regular lumber seam under another stud, or use a 20 foot 2x4 if you can get them. Hold together with c clamps (don't laugh pros) and use a small framing square, and start marking off for your layout. Put an X on both pieces on the end, ,come out 1 1/2 inches draw a line, 1 1/2 inch space, draw another line then x. Hook your tape on end pair of plates and make sure your exterior plywood breaks on a stud. Rough frame everything from same direction, on both sides of building.
Old 03-12-2011, 10:06 AM   #23
Framing Contractor
[QUOTE=bgbrown125;606937]
Originally Posted by Jackofall1 View Post
How tall do you plan on the walls being?
Edit
Garage door? one or two? double wide single?
Side door?
Rear garage door?
The plan is to have one 16' x 7' door garage door, one 36" entry door on opposite end, walls = 8', 4'x8' wood siding sheets
Is the garage door on the gable end or rafter wall?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 03-12-2011, 12:17 PM   #24
Rewards Points: 150
Once your walls are standing, and since you have blacktop,and have several outside wood bracing to help keep it from spreading, use a come-along in the middle inside up high ,using rope,chain or whatever. You can have perfectly plumb walls, but in the process of setting trusses,jerking to get them right ,walls tend to move, just check when your done. It pays to have a string on blocks, front to back, and keep an eye on it. When you do your outside sheeting ,have a drip aluim off-set piece between the upper and lower sheets. You might even consider nailing on a sheet of that plywood for the walls while its on the ground, or if you have enough help, put it all on, including the window. 6/12 pitch roof, so nail on a 2x4 on the sheeting for a shoe stop if your using neighbors, and nail 2feet up from edge, so you have room for first course of shingles. Elvis Presley music, and cold beer afterwards is like christening a ship.
Old 03-12-2011, 01:54 PM   #25
firehawkmph's Avatar
Rewards Points: 1,864
Garages are fun projects for diy'ers. However, it really helps to have at least one person on the job that is a good framing carpenter. It will eliminate a lot of mistakes and grief and the diy'ers can learn the right way at the same time and have a good time of it. I built a 24 x 36 garage for a younger cousin of mine. He had four of five of his friends show up along with himself. I did all the layout work, showed the guys how to use the nail guns and how I wanted things done. They did a good job and we got the whole thing up in one day, with the exception of shingles, siding, and overhead door. The girls had a small feast of a barbecue cooked up for us and plenty of beer at the end. And it was one of those summer days when it hit about 95 degrees and plenty of sun.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 03-12-2011, 05:21 PM   #26
Residential Designer
AndyGump's Avatar
Rewards Points: 666
Send a message via Skype™ to AndyGump
Or just count these members.
Sorry I just couldn't help myself.
It's a disease.
Andy.
AndyGump is offline   Reply With Quote
Old 03-13-2011, 09:49 AM   #27
Andy,
Where's the anchor bolts? lol
Mike Hawkins
The Following User Says Thank You to firehawkmph For This Useful Post:
AndyGump (03-13-2011)
Old 05-24-2011, 10:17 AM   #28
bgbrown125's Avatar
Rewards Points: 27
Change of Plans / Garage is now a Carport - Semi-enclosed
Well, I've procrastinated as long as I can. The primary reason for procrastination is that I have some physical limitations and I do not think that I can do the woek associated with a foundation.
The 20 x 20 garage will have to be a semi-enclosed carport. As I stated, this will take place on an asphalt drive. I plan to cut openings and "plant" posts as need to support the structure.
I still plan to have the 11 trusses built 5/12, 12" overhang. What spacing should I use for the support posts?
Help with materials list and everything will be appreciated.
Am I all wet in doing this or can I make it work.
Thank you again
Barry
bgbrown125 is offline   Reply With Quote
Old 05-24-2011, 12:52 PM   #29
dpach's Avatar
Everyone I know that has "settled" for a car port say the same thing: should have spent the extra for a real garage!
If you can't do the footing/concrete work, hire it out. Yeah, it adds to price (couple grand perhaps in labor), but do it once and do it right. Concrete work should always be done by experienced people because it is the foundation of any structure and you do not want it cracking, settling, etc.
Lots of people have already given you lots of advice on a garage, so take the advice and build a true garage.
Just my 2Cents.
dpach is offline   Reply With Quote
Old 05-24-2011, 08:17 PM   #30
Rewards Points: 150
This idea may not be code approved but you could do this, since you were going to dig for post anyway. Snap chalk lines on the blacktop,make sure the x measurements (corner to corner the same) use a pick or a jack hammer and dig down at least 3 feet both corners and two holes in the middle. The idea here is to pour a concrete beam on the blacktop and in the holes all level, so you'll have a good base to work from. Just use re-bar in all the concrete. The framing lumber used here can be lumber that you'll need for the building itself. Just get some threaded rod to keep the concrete from spreading in the form work (lots of them). Bury some L bolts in the concrete to hold walls down. You must have a level base to work from or you'll fight it from the start. If you get the building out of square it'll show up in the shingles.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Building house using wood from lot.... wilyum Building & Construction 4 06-29-2009 02:17 PM
building a deck with garage underneath johnny67 Building & Construction 6 06-29-2009 09:27 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
Crazy Garage Extension, Building over blacktop?!?! commissure General DIY Discussions 4 09-13-2007 11:09 AM
