Building 18x18 Cottage Need Help 12 12 Rafters - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-29-2012, 09:11 AM   #31
Rewards Points: 150
16' 2x12's will do!
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
Old 08-29-2012, 09:12 AM   #32
Thanks for all your help. I appreciate it.
driftwoodtackle is offline   Reply With Quote
Old 08-29-2012, 09:13 AM   #33
Rewards Points: 150
If you are going with collar ties and not a beamed ridge than make sure they are atleast 1/3 the way down the rafter for support.
Old 08-29-2012, 09:17 AM   #34
Rewards Points: 150
Which should be about 14' off the floor, but then again your plan will(should) show that.
Old 08-29-2012, 09:29 AM   #35
GBrackins's Avatar
Rewards Points: 2,108
Hammer,
no offense intended by my comments, trying to clarify the difference between collar ties and rafter ties .....
if dwift does not install a structural ridge beam or ceiling joists he would be required to install rafter ties which would be located in the lower 1/3 of the rafter. Rafter ties are typically installed at a minimum of 48" o.c. and are sized based upon the tension load they must resist.
collar ties which are typically located in the upper 1/3 of the rafter are installed to secure opposing rafters so that a high velocity wind perpendicular to the ridge (which will create a lower pressure on the leeward side of the roof) will not lift/pull the leeward rafter away from the ridge. You can use a metal strap tie installed on the exterior side of the roof sheathing that is attached to the opposing rafters to prevent this lift/separation in lieu of collar ties.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 08-29-2012, 10:01 AM   #36
Rewards Points: 150
No offense taken Gary, one thing you learn in this business is you can always learn something. Not quite the way it's done where i am but interesting read.
Building a pergola having issues with "bowing" in rafters. chriscarney Building & Construction 3 06-02-2012 05:53 PM
Old Building problems jake62 Building & Construction 5 08-20-2010 09:32 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 07:35 PM
