Building 18x18 Cottage Need Help 12 12 Rafters - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-07-2012, 12:57 PM   #16
Framing Contractor
Originally Posted by framer52
Sounds like it, Joe.
It could be 18'1" including the sheathing. He has to have a ridge beam too for a cathedral ceiling unless he's using rafters ties for a clipped ceiling...but he didn't say that.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
driftwoodtackle (08-07-2012)
Old 08-07-2012, 01:09 PM   #17
Thanks joe. My local lumber yard wanted me to order all 16 footers. Glad i found the forum.
driftwoodtackle is offline   Reply With Quote
Old 08-07-2012, 01:25 PM   #18
GBrackins's Avatar
Rewards Points: 2,108
do you know what your ground snow load is if any? what about any wind loads? what species of wood are you using?
you said 12:12 pitch cathedral roof, I take it you mean without any ceiling joists/rafter ties so that your ridge will have to support 9' of tributary load from the roof?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 08-28-2012, 07:37 PM   #19
Rafter help. Can anyone help with the width of rafter boards
Old 08-28-2012, 08:01 PM   #20
GBrackins's Avatar
this link will take your to the 2009 International Residential Code Rafter Tables. You will need to find the species of wood and grade your for your rafters, including your live and dead loads. This will give you the maximum span for your rafters
http://publicecodes.cyberregs.com/ic...9_8_par025.htm
Gary
Old 08-28-2012, 08:13 PM   #21
AHH, SPANS!!!
Rewards Points: 1,166
as others have mentioned, exact dimensions are needed. At the wall top plates what are the measurements between the outside walls, inside of wall to inside of wall? Is it a 2x4 wall or 2x6 or??
hand drive is offline   Reply With Quote
Old 08-28-2012, 08:16 PM   #22
Its a 18 x 18 square. And they are 2x6 walls
Old 08-28-2012, 08:28 PM   #23
GBrackins's Avatar
will you have ceiling joists installed?
Gary
Old 08-28-2012, 08:31 PM   #24
No. All exposed. No loft.cathedral cielings
Old 08-28-2012, 08:33 PM   #25
Framing Contractor
Rewards Points: 120
That changes EVERYTHING!
Ridge beam is necessary. If you don't know what this means, you are in over your head. Get someone qualified to work on this.
sixeightten is offline   Reply With Quote
Old 08-28-2012, 08:36 PM   #26
I know what a laminated ridgebeam is. I was told by the lumber yard all i will need is a 2x12x20 ridge beam. Which i know is not correct.
Old 08-28-2012, 09:15 PM   #27
GBrackins's Avatar
not even close for a structural ridge beam ..... it would work if you were installing ceiling joists or rafter ties where it would simply be a ridge board.
you'll be looking at something like a 2-ply 16" LVL or 3-ply 14" LVL and you'll have to account for somewhere around 3800 pounds of load at each end of the ridge beam.
Have the lumber yard contact their rep for their engineered wood products to determine the actual size of beam needed and provide engineer's certified calculations for the building official (if needed). Engineered wood products fall outside the prescriptive nature of the building code.
You never posted what your ground snow load was so the actual load may vary from what I showed. You'll need to size the support column based upon the species of wood used for your sill plates so that you do not crush the wood fibers and cause the column to settle.
I typically install collar ties directly under the ridge beam attached to the sides of the rafters at each pair of rafters. Either that or Simpson Strong-Tie LSTA24 strap ties over the roof sheathing to connect opposing pairs of rafters together.
Just my thoughts ....
Gary
Old 08-28-2012, 09:29 PM   #28
Thank you for your help.
Old 08-29-2012, 07:41 AM   #29
AHH, SPANS!!!
Exactly what I was thinking, a good 2x6 or 2x8 collar tie butted up to the underside of the ridge or down below the ridge some and nailed with a precise nailing pattern to the rafters...
Old 08-29-2012, 07:58 AM   #30
GBrackins's Avatar
I typically use a 2x6 collar tie since our exterior wall are 99% of the time 2x6, why waste scraps?
Gary
Building a pergola having issues with "bowing" in rafters. chriscarney Building & Construction 3 06-02-2012 04:53 PM
Old Building problems jake62 Building & Construction 5 08-20-2010 08:32 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
International building code and permits rforsha Building & Construction 4 08-28-2006 06:35 PM
