Building 18x18 Cottage Need Help 12 12 Rafters - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-07-2012, 12:27 PM   #1
building 18x18 cottage need help 12 12 rafters
Hello. Im building a 18 x 18 cottage. Already have crawlspace foundation and walks up and tyvek done. I have 8 foot walls. And putting a 12 12 pitch cathederal roof on. Using 2 x 12 rafters. How long do they have to be. Thank you. We want a 1 foot overhang and 1 foot extension on both ends.
driftwoodtackle is offline   Reply With Quote
Old 08-07-2012, 12:37 PM   #2
Framing Contractor
What size ridge....what is the exact span? Is the sheathing flush to the top of the top plate?
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
driftwoodtackle (08-07-2012)
Old 08-07-2012, 12:44 PM   #3
This calculator is helpful for that sort of thing.
http://www.pole-barn.info/roof-rafter-calculations.html
jbs11 is offline   Reply With Quote
Old 08-07-2012, 12:46 PM   #4
Rewards Points: 12,802
See if this helps.
http://www.blocklayer.com/Roof/GableEng.aspx
Old 08-07-2012, 12:55 PM   #5
Thanks for the help. It asks me how long my rafters are. But that was my question. Guess i can order longer ones and cut off access. Thanks to all
Old 08-07-2012, 01:07 PM   #6
Rewards Points: 1,294
12.72' from tip of ridge to edge of top plate.
danpik is offline   Reply With Quote
Old 08-07-2012, 01:20 PM   #7
Framing Contractor
If you tell me the answers to my questions....I can give you the exact length. Why buy longer than needed rafters and waste money.
Joe Carola
Old 08-07-2012, 01:31 PM   #8
Joe. I am not sure of all your questions. Our walls are 8 ft high. And cottage is 18x18. We are using 2x12 rafters. They will be 24 inches on center. It is a 12 12 pitch. Open cathedral ceilings inside cottage. We need a roof cap for ventilation and a vented soffit on bottom. This is our first building we have built. Thanks.
Old 08-07-2012, 01:34 PM   #9
And the ridge board is 20' giving us 1' overhang on each end.
Old 08-07-2012, 01:35 PM   #10
And we wanted 1 feet overhang.
Old 08-07-2012, 01:48 PM   #11
Framing Contractor
What is the width if the ridge beam? Does the outside measure exactly 18'?.
Joe Carola
Old 08-07-2012, 01:50 PM   #12
Rewards Points: 528
Sounds like it, Joe.
framer52 is offline   Reply With Quote
Old 08-07-2012, 01:50 PM   #13
Framing Contractor
Who designed the roof? Do you have plans?
Joe Carola
Old 08-07-2012, 01:52 PM   #14
Rewards Points: 528
Plans??
Who needs stinking plans
Old 08-07-2012, 01:52 PM   #15
The ridge beam is a 20' 2x12. And the plywood would cover the entire 20 feet. So we will have a 1 foot overhang from the cottage on both sides. I hope i answered your question. Thanks for the help.
Building a pergola having issues with "bowing" in rafters. chriscarney Building & Construction 3 06-02-2012 05:53 PM
Old Building problems jake62 Building & Construction 5 08-20-2010 09:32 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 07:35 PM
