Build Out Bonus Room - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-23-2013, 01:50 PM   #1
Rewards Points: 113
build out bonus room
I have an area over my garage that I believe can be used for additional living space. Trusses have provisions for knee walls and are 2x8, 24 o.c. Question 1: The floor joist are 2x8 24"o.c. and span 11'9". The total garage span is 23'. There is a splice that uses a mending plate to hold both joists together. Are the joists structurally sound for 3/4 plywood with laminate flooring? Would I need to use blocking to give flooring more support? Room will be used for crafts - no real heavy objects. Ques 2: what is best way to insulate? thanks
EFTHIM is offline   Reply With Quote
Old 12-23-2013, 01:56 PM   #2
Rewards Points: 14,312
Need to go back and add your location to your profile for questions like that.
Just go to quick links to edit.
How to build a Sand Blast Room? etchedimpressio General DIY Discussions 9 09-23-2012 06:44 AM
Framing To Build Sun Room Bench Seating - See Pictures of Area LuckyFoot15 Remodeling 10 09-03-2012 05:29 PM
Well Room (Cold Room) Issue--Advice Needed TomPgh Building & Construction 11 01-03-2011 06:31 PM
Open channels down each side of bonus room gable end wall from attic? fdecker Building & Construction 4 11-17-2010 04:28 PM
Builder skipped ceiling joists in bonus room need advice minicus Carpentry 31 08-11-2008 10:44 PM
