Old 10-20-2009, 11:29 AM   #1
Default Bricks cracking?
Hi all,
I'm finding a problem with the bricks on the first or second row near the ground level around my home.
There are about 20 or more bricks doing the same thing in different spots around the home. The brick face is cracking and flaking off. I have attached a picture of one of them to show what I'm talking about.
What is the cause of this and how to fix it? My home is about 30 years old.
PaulBob is offline   Reply With Quote
Old 10-20-2009, 12:40 PM   #2
your bricks are spalling. this link has some good information on what causes it - in your case it is probably the lower quality brick. wikipedia explanation of spalling as a mechanic.
basically the brick absorbs too much water and the back pressure from the water causes part of the brick to fall off (or it freezes and expands.) i believe there are some sealants you can get that will slow this down and prevent water from penetrating the brick. you should also make sure that your weeps are clear and you have good drainage behind your brick. spalling can also occur from the inside if moisture in the wall isnt able to drain out.
cellophane is offline   Reply With Quote
Old 10-20-2009, 12:45 PM   #3
And if this is the case, sealing the brick may just compound the problem.
sdsester is offline   Reply With Quote
Old 10-20-2009, 04:55 PM   #4
Spalling often happens at the bottom of the wall as these bricks are often wetter through rain bounce, or water running down the inside face. In the UK now the codes mean that frost resistant bricks have to be used at low level below DPC.
Crptoflorescence sometimes does this to brickwork, and sealing the wall can increase the problem.
stuart45 is offline   Reply With Quote
Old 10-20-2009, 05:59 PM   #5
Read the links. Thanks.
A few questions,
1) What are "weeps"
2) How to fix the problem once it happens
3) How to know if sealing it will work?
I just bought some Behr concrete and masonary water-proofing stuff because I poured a cement pad in my backyard and want it to stay looking nice. This stuff I bought is a satin or flat mat finish that is clear so you can barely see it. Should I apply that to the bricks around the bottom 2 rows or so?
Thanks again!
I don't know much about this kind of stuff so I'm glad you guys do.
Old 10-20-2009, 06:14 PM   #6
Weep holes are open cross joints(head joints) at the bottom of the wall which allow water to escape from inside the cavity. We put them in every 4th brick, nowadays with a plastic or nylon insert.
Siloxane sealant is said to allow the walls to breathe.
Old 10-20-2009, 08:37 PM   #7
silicone siloxane - we use prosoco
itsreallyconc is offline   Reply With Quote
More On This Topic
Create cement stones with your hand and footprint impressions in them and give them as gifts for Grandparent's Day, Mother's Day or Father's Day. You can make one a year and place them in order by date in the backyard to make your own walk of fame. Read More »
The dry-mortar method is an easy way to fill the space in masonry joints when you're building a patio. One of its advantages is that the mortar keeps those pesky weeds from sprouting. Whether you're using bricks or concrete slabs, consider filling the... Read More »
The soil in the north Texas area can be challenging, to say the least. Its clay alkaline soil naturally withstands long periods of drought and retains nutrients. But north Texas soil also shrinks in the winter and swells or cracks in the summer. The soil... Read More »
Hello! My name is Denise Robertson and on behalf of expertvillage.com, I am here to talk about how to dress on a budget. We are going to continue on with our model Danielle. She is using the same satin shirt that she wore and she added a satin black... Read More »
There's unsightly drips, runs and smudges of paint all over the brick work on your house. You tried paint remover and a wire brush, but that just left pinkish smudges that look even worse. You powerwashed your house, which left both the brick and the... Read More »
Brick Home - brick fronts cracking off AndrewF Building & Construction 2 09-10-2009 06:48 PM
Use stone dust under bricks to form a border around flower bed Curious123 General Discussion 4 08-23-2009 05:41 PM
Paver Sand and Blue/Grey Colored Bricks Curious123 General Discussion 4 08-13-2009 10:22 PM
certainteed cement siding cracking! wichitawings Building & Construction 6 05-28-2009 06:58 PM
Problem with bricks in fireplace box pulling away from interior wall proofer Building & Construction 1 06-15-2008 09:54 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
