Bricklaying Cement Mix - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-08-2005, 02:01 AM   #1
Question
Bricklaying cement mix
could someone please tell me the mix of sand and cement for bricklaying? and do i need to add anything else to the mix?
is it the same mix for a concrete screed?
millymollymandy is offline   Reply With Quote
Old 08-08-2005, 10:37 PM   #2
hi
You were asking about a 12" garden wall in a previous post. I don't believe you really need to go threw the measures you are asking about for your final goal. I am posting a link on building retaining walls from hometime. I hope it is of some help deciding what you actually will have to do for your application
http://www.hometime.com/Howto/projects/retain.htm
But anwer you qesation the easist thing for a diy to do is buy a prebleded product like the links below
http://www.quikrete.com/catalog/MortarMix.html
The mix a mason uses vary and I would welcome other input but a produt like this should be fine.
Here is quickrete tip on makin brick walls
http://www.quikrete.com/diy/BasicBrickConstruction.html
Don't forget that you wll want "cap " the top of you wall with somthing as well.
Mgmopar
MgMopar is offline   Reply With Quote
Old 08-09-2005, 02:05 PM   #3
many thanks for your helpful comments
Old 08-09-2005, 02:22 PM   #4
4 sand 1 cement and add a small amount of Plasticiser in a mixer place 12 sand 3 cement
jake is offline   Reply With Quote
Old 08-13-2005, 07:35 AM   #5
many thanks
