Bricking In A Window - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-10-2012, 12:43 AM   #1
Rewards Points: 49
bricking in a window
I have a shower window i want to remove in my house.
I was prepping/cleaning the inner cinderblock wall for the brick layer.
I noticed there was a header above this window.
This is a tiled window which is 3' x 3'.
Will removing the header drop the wall above it? I think there is an attic ledger above this header, so no more bricks.
Should i leave the header in and have him brick up to the header for the inner wall?
How can i transfer some of the load from the header into the bricks, with shims? should i even be worried about that since its only a single story.
Whats better to use brick or cinderblock? not sure which is stronger.
I am a clueless homeowner.
john_bry is offline   Reply With Quote
Old 10-10-2012, 07:51 AM   #2
AHH, SPANS!!!
Rewards Points: 1,166
By header do you mean metal brick lintel? will you be using drywall for the inside bathroom wall? It is not recommended to remove headers...
hand drive is offline   Reply With Quote
Old 10-10-2012, 11:40 AM   #3
Rewards Points: 3,418
As previous post said,do not remove the lintel,and why not ask your bricklayer what to use.
Canarywood1 is online now   Reply With Quote
Old 10-10-2012, 11:45 AM   #4
Rewards Points: 13,276
If the wall is already block, why would they use brick to fill it in?
There just going to use block the same size as you already have and may have to cut the top row to fit.
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 03:05 PM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 06:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
