Bricking The Outside Of A Home - Options? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-06-2009, 06:34 AM   #1
Lost..
Rewards Points: 336
Bricking the outside of a Home - options?
I plan to build my own home in the near future, and I am looking for options on what I can use on the outside of the house. The original plans call for brick, and this is what I really want. However, to save money I may go with something different. I'm not sure of what all the options are.
What can be used in place of brick, and how would it rank in cost compared to brick?
Again, first choice is brick, but still not sure if I will go this route because of cost.
J S Machine is offline   Reply With Quote
Old 10-06-2009, 07:22 AM   #2
Remodeling Contractor
you could use a brick veneer to save costs and keep the look you want.
Old 10-06-2009, 07:24 AM   #3
Lost..
Rewards Points: 336
Where can I find some examples of this?
Old 10-06-2009, 08:27 AM   #4
Rewards Points: 1,232
As a rule, regular brick is going to be cheaper than an adhered veneer brick. Stucco is another option, as is rock.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 10-06-2009, 09:09 AM   #5
But a DIY'er can work with the veneer. Laying a true brick facade takes much more skill and knowledge to get the moisture control right and proper brick layout.
Old 10-06-2009, 01:18 PM   #6
Rewards Points: 582
Brickwork to me is the best material for houses, as it looks better as it matures, is quite low maintenance and can last for hundreds of years. However when done badly it can look a real mess and ruin the looks of the house. The best brickwork that I have seen in general was done by the Victorian bricklayers with lime mortar.
stuart45 is offline   Reply With Quote
Old 10-06-2009, 01:40 PM   #7
Flashing for stucco is just as if not more important for stucco than it is for brick; both systems work in the same basic way. Adhered veneer (brick) is just the final coat of a cementious stucco wall system.
Old 10-07-2009, 11:47 AM   #8
Rewards Points: 582
What about pressed steel for the external walls. Cheap and easy maintenance. Look at this classic from the British Iron and Steel Federation. The asbestos roof completes the charming appearance. Could Frank LLoyd Wright have designed anything this good. Landscaping in this street is usually finished with a load of old engine parts in the front garden. This one is unfinished.
Color options for a small cape style home Staticman2 General DIY Discussions 2 06-20-2009 12:53 PM
Need some advice on buying home termite & water damage. Mr Heshup General DIY Discussions 1 03-29-2009 03:06 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
