Old 10-16-2010, 08:33 PM   #1
Brick work to repair a Chimney
Hello:
A few weeks ago, a very bad storm knocked the top of an old brick and mortar chimney. This is for a neighbor who is an elderly woman with no money, so, I volunteered. Attached are a few pics of the chimney. I have worked construction in the past, however, I have never done a repair like this one.
A few thoughts:
- The brick needs tuck pointing for the entire chimney above the roof line. I'm thinking about removing the loose mortar and grinding back a little, then, filling with new mortar.
- I removed all of the loose bricks at the very top and I physically pushed on the chimney. It feels pretty solid, however, I'm definitely thinking I should remove the top to layers to level it off and rebuild from that point.
- A clay cap sounds like a good idea, but, I'm not sure if it would be best in this situation.
- The home is located in Northwest Indiana near the Illinois border (Whiting, IN). I have no clue where to get materials for this type of job. Big box stores?? Menards, Home Depot?
Again, this is a charity job, so, I would deeply appreciate any advice how as to how I should proceed.
Brick work to repair a Chimney-img_5600.jpg   Brick work to repair a Chimney-img_5593.jpg   Brick work to repair a Chimney-img_5595.jpg   Brick work to repair a Chimney-img_5597.jpg
worthspending is offline   Reply With Quote
Old 10-16-2010, 11:15 PM   #2
that chimney probably should be rebuilt from the roof up. new flashing too.
what is the round pipe? sewer vent?
1910NE is offline   Reply With Quote
Old 10-17-2010, 08:58 AM   #3
Concrete & Masonry
Is the chimney still functional or abandoned?
jomama45 is offline   Reply With Quote
20 year old Brick Wall Repair Bobrobert General Discussion 15 11-22-2011 04:07 PM
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 01:38 PM
Concrete block Chimney problems scoggy Building & Construction 0 03-09-2010 08:00 PM
Repair crumbled brick walkway timcsi Building & Construction 12 12-18-2009 12:11 PM
crumbly brick work joe_cowboy Building & Construction 2 09-11-2008 03:58 PM
