Brick Work For An Old Garage, Steel Frame Needed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-12-2011, 12:22 PM   #1
Rewards Points: 198
brick work for an old garage, steel frame needed
i have an old garage detached from the house. The brick work must of been neglected for years and a lot of the mortar and brick have fallen out around the door entrance.
i tried to patch up the morter today but have realized that so much of the mortar have been blown away for years that a rebuild of the entire base will prob be necessary. having a steel frame built was suggested to me by the home inspector a while back and i was wondering if that's a viable solution? if i do go with a steel frame, is it a cheaper solution than just hire someone for mortar work??? is steel frame do the work?? and finally, what type companies i should look for to have this frame built.
thanks
vote4Pedro is offline   Reply With Quote
Old 02-12-2011, 01:48 PM   #2
Carpenter
dtsman's Avatar
What is the purpose of the steel frame?
A brick guy would probably use a grout bag to squirt the mortar into the brick veneer to disperse it more evenly. You can get one at home depot too.
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
dtsman is offline   Reply With Quote
Old 02-12-2011, 01:53 PM   #3
Rewards Points: 582
Have you got any photos?
stuart45 is offline   Reply With Quote
Old 02-12-2011, 02:52 PM   #4
Rewards Points: 5,336
thanks
If the mortar is that deteriorated, it needs to be repaired. What you need to do would be contingent on the extent of the issue.
A steel frame has no place in the repair. A steel lintel, maybe.
Ron
brick front on a garage matt p Building & Construction 0 05-14-2010 10:35 PM
Garage brick wall repair TANME General DIY Discussions 2 02-04-2010 07:19 AM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 07:41 AM
wood roof frame on old brick house Stealthfox Roofing/Siding 9 09-03-2008 08:55 PM
New house purchase - work needed - how much will it cost? mchu6am4 Building & Construction 1 03-10-2007 07:10 AM
