Old 11-20-2007, 04:38 PM   #1
Brick wall cracks
I have a relatively new home brick veneer and I am getting cracks in the brick work randomly around the house. It appears as though the mortar has shrunk and has not stuck to the brick work. I have never seen anything like it before. I am confident it is not related to foundation movement as they are predominantly horizontal and all around the house.
Appreciate anyones thoughts on this.
moogun is offline   Reply With Quote
Old 11-21-2007, 11:13 PM   #2
remodeling pro
Brick wall cracks
Sounds like you are thinking in the right direction. There are really two posibilities for the excessive mortar shrinkage. It could have been mixed with too much water,causing excessive shrinkage when it dried, or the bricks could have been exessively dry and sucked the water out of the mortar before it could cure properly. As for the mortar not sticking to the brick, that is usually an indication of a mix that contains too much sand.
troubleseeker is offline   Reply With Quote
Old 11-26-2007, 03:03 AM   #3
Brick wall cracks
Is there a way of testing the mortar to ascertain the correct mix?
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Siding and Brick veeneer wall? sandyman720 Building & Construction 9 08-13-2007 05:02 PM
Brick wall needs repainting BilHam Painting 3 07-19-2007 10:17 PM
Hole in wall w/ stress cracks... lots of detailed pics (NOT 56k connection friendly) Thaipo Building & Construction 8 05-21-2007 07:40 AM
Exterior brick wall has cracks and moves...is this a huge problem? ConstantChange Building & Construction 3 06-16-2006 10:09 AM
