Old 01-12-2010, 04:39 PM   #1
Brick vineer?
I was at lowes the other day and noticed they had a type of brick vineer it looks like its actual brick but half as thick, there are no grout lines and every 4th row of it screws onto the house it has an overlapping latch like system... anyone ever see this stuff installed before or know what it is called? they had it so high up I couldn't read the name of it off the display... it seems nice for a house that doesnt have a masonary lip to lay bricks on already
BlueBSH is offline   Reply With Quote
Old 01-12-2010, 05:01 PM   #2
concretemasonry's Avatar
Brick vineer?
That was probably NovaBrik, that is hung on the studs in accordance with code approvals with a moisture barrier behind it, similar to vinyl or wood or fiber cement siding.
The load is not a problem with properly constructed frame wall and actually increases the shear resistance of the wall.
It is not cheap and do not let a mason install it because they are much more fussy and acurate than siders or amateur "carpenters".
concretemasonry is online now   Reply With Quote
20 year old Brick Wall Repair Bobrobert General Discussion 15 11-22-2011 04:07 PM
Exterior Brick Wall with No Sheathing? beesan Building & Construction 1 12-08-2009 06:57 AM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 07:41 AM
New opening in a brick veneer wall - installing new brick ties? GrantJohnson Building & Construction 3 01-28-2009 11:17 AM
Sealing historic brick tenzo General Discussion 2 11-22-2008 04:04 PM
