Brick Veneer With SIP Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-14-2011, 12:20 PM   #1
brick veneer with SIP walls
What's the best way to attach a brick veneer across a 2-inch air space to a Structural Insulated Panel (SIP) wall, with 7/16-inch exterior sheathing? There are no studs, so you're simply attaching to the sheathing. I'm looking at using 2-pc. brick anchors, not corrugated ties, but don't know if I should nail or screw, or what the spacing of fasteners should be. One SIP manufacturer said simply, "Put in twice as many brick ties as you would for a wood stud wall."; Another SIP manufacturer gave me nail & screw pull-out values tested on their SIP, but without an engineer, how do you know what pull-out value you need? Is there a rule of thumb?
tap210 is offline   Reply With Quote
New Air Conditioner and Brick Veneer RayB1 Building & Construction 2 11-30-2009 09:54 PM
Brick veneer or soffit/fascia first? jogr Building & Construction 2 11-13-2009 02:02 AM
Attaching pergola to brick veneer house Mikedks Building & Construction 4 12-28-2008 01:01 PM
Sealing historic brick tenzo General DIY Discussions 2 11-22-2008 04:04 PM
Old Brick House inside walls rick32 Building & Construction 6 11-08-2007 07:49 PM
