Brick Veneer Pulling From Front Of House, How To Re-anchor? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-12-2008, 12:42 PM   #1
Brick veneer pulling from front of house, how to re-anchor?
I have half brick veneer running up to about 4' off the ground around my garage. I see that on the front of the garage the brick is pulling away (all in a 1 piece panel) and leaning out slightly. I thought that I could maybe anchor it from the backside (inside of garage) but the brick is a veneer so I'm afraid it may crack if I drill into it. Anyone else have this problem or solution to it?
tidal9 is offline   Reply With Quote
Old 06-12-2008, 01:34 PM   #2
Registered User
Termite's Avatar
The only thing I can think of is called a Simpson "Heli-Tie."
http://www.simpsonanchors.com/catalo...ical/heli-tie/
I'm sure they're not cheap, but they're made for this. They won't draw the brick closer to the wall, but will stabilize it.
You might want to determine why it is pulling away before trying to fix it. Is it sitting on a foundation ledge? On a piece of angle iron? What's causing it to move?
Old 06-12-2008, 09:35 PM   #3
Rewards Points: 1,232
Find the problem, fix that, then stabilize the wall. The Heli-ties work great to stabilize the wall once you fix the problem and correct the lean.
Tscarborough is offline   Reply With Quote
Old 06-12-2008, 09:56 PM   #4
Yeah,
Unfortunately the previous owner had let the gutters leak all over the front walkway, which washed out fill from under the front of the garage, causing it to settle a bit and crack the walkway in the process directing more water to it. We have since remedied the gutter situation and pulled up the walkway and replaced with pavers to pitch the water away from the location. It's not severe enough to have it mud-jacked I don't think, but I'm guessing that''s why the veneer failed in that area.
Old 06-13-2008, 04:54 PM   #5
I would call a foundation repair place. They usually give free appraisals.
TexasEd is offline   Reply With Quote
Old 06-13-2008, 08:08 PM   #6
concretemasonry's Avatar
Rewards Points: 2,594
Don't gues - If the veneer is failing because of the erosion, it is not properly supported by the foundation.
Find the cause first!
concretemasonry is offline   Reply With Quote
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
Power Washing Brick House bobo Building & Construction 3 09-24-2006 05:53 PM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 02:57 PM
Exterior brick wall has cracks and moves...is this a huge problem? ConstantChange Building & Construction 3 06-16-2006 09:09 AM
Care of Brick front sherlock General DIY Discussions 2 08-12-2005 06:41 PM
