Old 01-26-2011, 12:52 PM   #1
Post
brick veneer
Can I use thinset to install my brick veneer on wire mesh over a wood frame I've constructed on my interior arched doorway rather than motar ?
IVANHO is offline   Reply With Quote
Old 01-26-2011, 03:25 PM   #2
brick veneer
What is the products dimensions? Is this the 1/2" thick product that used to be put up inside to mimic real brick?
Ron
Old 01-26-2011, 03:58 PM   #3
brick veneer
It's Elderado brick which is about 1" thick and I'll be using corners & alternating back and forth on a 3 1/2" wall. I'm only doing the arch of the door at the top and then building fake post's from the floor up to the arch at both sides. Elderado said to use motar as a scratch coat and then apply motar to the bricks about the consistency of peanut butter. It's going to be a pain to mix motar out side when it's 10 above zero & was thinking thinset if it works would be much easier.
Old 01-26-2011, 04:52 PM   #4
brick veneer
Where did you plan to mix the thinset?
Mix it inside. Put down plastic and a drop cloth and mix it on top.
Ron
Old 01-26-2011, 10:27 PM   #5
brick veneer
No, you have to do a mortar scratchcoat over the metal lath, then you can thinset the brick to the scratchcoat.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Fireplace Brick Veneer TV Mounting RICKM15752 Building & Construction 3 12-14-2010 05:03 PM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 09:50 AM
Replacing band joist behind brick veneer jzambon Building & Construction 0 03-09-2010 12:58 PM
New opening in a brick veneer wall - installing new brick ties? GrantJohnson Building & Construction 3 01-28-2009 11:17 AM
Brick Veneer on steel angle iron sandyman720 Building & Construction 3 07-09-2007 09:21 PM
