-   -   brick veneer (http://www.diychatroom.com/f19/brick-veneer-93571/)
IVANHO 01-26-2011 12:52 PM
brick veneer
Can I use thinset to install my brick veneer on wire mesh over a wood frame I've constructed on my interior arched doorway rather than motar ?
Ron6519 01-26-2011 03:25 PM
What is the products dimensions? Is this the 1/2" thick product that used to be put up inside to mimic real brick?
Ron
IVANHO 01-26-2011 03:58 PM
thinset verses motar
It's Elderado brick which is about 1" thick and I'll be using corners & alternating back and forth on a 3 1/2" wall. I'm only doing the arch of the door at the top and then building fake post's from the floor up to the arch at both sides. Elderado said to use motar as a scratch coat and then apply motar to the bricks about the consistency of peanut butter. It's going to be a pain to mix motar out side when it's 10 above zero & was thinking thinset if it works would be much easier.
Ron6519 01-26-2011 04:52 PM
Where did you plan to mix the thinset?
Mix it inside. Put down plastic and a drop cloth and mix it on top.
Ron
Tscarborough 01-26-2011 10:27 PM
No, you have to do a mortar scratchcoat over the metal lath, then you can thinset the brick to the scratchcoat.
