Old 09-21-2007, 02:41 PM   #1
Brick up against sliding patio door with J Channel?
I have a sliding patio door that has an integrated J channel (Certainteed).
I am going to put up a 3 ft brick veneer wall. How do I lay the brick around and under the door?
sandyman720 is offline   Reply With Quote
Old 09-22-2007, 07:37 PM   #2
mason
Get a mason to do it.
Well, if you do it yourself you will need a saw. I suggest cutting the brick to fit vertically between the slab and threshhold of the door. Put the good end up of course.
For the sides, just but the brick up to the j channel, then go back and silicone up around where the brick and j channel meet.
Remember to put your weep holes in the bottom for drainage.
6stringmason is offline   Reply With Quote
Old 09-28-2007, 08:47 AM   #3
If I put the brick up and leave a 1" gap between the sheathing and the brick, the brick will stick out pretty far past the integrated j channel. will this look weird? This is the top view
Sliding Patio Door Installation flyultralite Building & Construction 11 05-04-2007 12:06 PM
Brick Patio - leveling Patcho Landscaping & Lawn Care 1 04-24-2007 02:43 PM
Steps on an umortated brick patio schott_robert Building & Construction 2 12-04-2006 08:15 AM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
Patio sliding door,Retro or new construction. Doug Crf Carpentry 3 09-11-2006 12:56 AM
