Brick Steps - Next Step? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-09-2010, 08:14 PM   #1
Brick Steps - Next step?
I tore up the Disaster'De'Builder and found the base was a mix of pieces of brick, wood and, well, bottle caps, etc. on top of a pre-formed concrete set of stairs. It fell apart and I cleaned out the crap and then filled it in with Quikrete, and it came out fairly decent. I tried to level with the pre-formed concrete steps and came pretty close.
I did not put in flashing yet, but will be doing that tomorrow and trimming the clapboard away from under the door to install the face plate under the door.
Taking suggestions how how to finish this up. Someone I live with suggested I frame around the top with wood to match the other steps leading up to it, then just fill with gravel and sand and set the bricks into that instead of using mortar. This is how the other steps are set up that lead up to the front stoop as you can see at the very bottom of the picture.
Thoughts? Perhaps any masons on the site interested in taking this small job on?
ironmm is offline   Reply With Quote
Old 09-09-2010, 08:19 PM   #2
Old School
Willie T's Avatar
Now, just go take a look at the bricks you now have set in gravel and sand. I think you can answer your own question about the advisability of doing that on steps.
Willie T
Old 09-09-2010, 08:24 PM   #3
True, but they just need to be re-set and leveled and it's good to go again. Those are also original, the steps have been redone twice already.
I was actually told this is a good way to go because the mortar won't stay past 3-5 years up here in the northeast.
Capping Concrete Steps with Brick and Buestone??? bryankloos Building & Construction 0 07-06-2010 12:59 PM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
Brick steps failing sk8z Building & Construction 10 03-28-2009 03:16 PM
Brick Step Construction edstevn Building & Construction 1 11-28-2008 10:33 AM
forms for semi-circular concrete steps cirsteps Building & Construction 7 10-22-2008 11:22 PM
