Brick Step Construction - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-26-2008, 03:21 PM   #1
edstevn
Smile
I own a 1923 cedar sided center hall colonial house. It has 4 wood steps going up to the wood porch. The steps need to be replaced. I thought about building the new steps out of brick and then using sandstone for the treads. The current wood steps are built off on a concrete pad. I dug below the concrete pad on one side to see if I could find a footer. I found some red brick/red clay tile. This might indicate the house probably was originally built with brick steps. My question is, if I build new brick steps, do I build them off of the pad or do I remove the pad and the old footer and start new? I want these steps to last as long as I own the house.
edstevn is offline   Reply With Quote
Old 11-28-2008, 10:33 AM   #2
step question
I would say, depending on your area, that a frost footing would be needed. If you live where there is frozen ground in the winter, it would be necessary. However, depending on how large you will be making the steps, you might get away with just going over the old brick.
Northland101 is offline   Reply With Quote
new construction no Brick ledge Justbeck101 Building & Construction 25 11-19-2012 01:03 PM
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 03:07 PM
Sealing historic brick tenzo General DIY Discussions 2 11-22-2008 03:04 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
