Brick Over 1" Foamboard On Plywood - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-24-2011, 09:34 PM   #1
Brick over 1" foamboard on plywood
Do I need Tyvek if I use 1" foamboard over 1/2" plywood? The house is being bricked using poly weave and with proper weeping holes. Also should I caulk the outside of my mud/foundation sill plate?
waddington is offline   Reply With Quote
Old 10-24-2011, 09:35 PM   #2
No. Just go for it.
Old 10-25-2011, 09:44 AM   #3
Rewards Points: 5,326
How is the brick being tied to the walls? Normally the brick ties are nailed to the studs every 16" vertically and horizontally.
Ron
B. Franklin 1759
Expansion / Contraction 2x4 whitewood studs on brick bpardo Building & Construction 2 08-29-2011 03:22 PM
TV Mount onto Brick Fireplace- Brick Integrity? andrew.volkart Building & Construction 4 03-01-2011 08:21 PM
Started Exposed Brick Wall, Studs within brick, should I stop? perry167 Building & Construction 4 01-05-2011 10:41 AM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 09:50 AM
Sealing historic brick tenzo General DIY Discussions 2 11-22-2008 04:04 PM
