Old 10-13-2009, 09:39 PM   #1
Default brick mould with j-channel?
hi i am new to this forum, i am looking for a vinyl or pvc brick mould ( white ) with the j-channel for vinyl siding already made into it ( like they do with the new windows ) i would like to use this on a new exterior entry door, and also around a new garage door, is there somewhere i can buy this or order it from?
thanks, sincerely, jim
jd140400 is offline   Reply With Quote
Old 10-14-2009, 08:02 AM   #2
If you are referring to vinyl windows, that is completely different. I am not aware of such a brickmold. They do have composite and solid vinyl brickmold, but not with J-ch attached.
Old 10-14-2009, 10:18 AM   #3
In way over my head.
Clutchcargo's Avatar
Is it as simple as buying the brick mould and dato a groove?
You'll never be sorry you bought the best.
Clutchcargo is offline   Reply With Quote
Old 10-14-2009, 03:02 PM   #4
General Contractor
It should be available at your local siding or building supply houses (not the big box stores). If for some reason they don't stock it they should be able to order it for you.
ARI001 is offline   Reply With Quote
Old 10-14-2009, 11:39 PM   #5
There is a product made by Gossen company that is exactly what you're looking for. i think you can locate a local dealer on their website.
dealer69 is offline   Reply With Quote
Old 10-15-2009, 11:38 PM   #6
Default gossen corp
thanks for the tip on the " gossen corp" i have sent a request to them for more info, hoep fully will find an area dealer that i can purchase through, i also had a suggestion to use a dado blade on a standard piece of vinyl brick mould, the only one i could find had a recess built into the back side thus preventing me from being able to " dado " it, it was a good idea until i discovered that, these sites are great sources of information thanks to everyone! have a good day!
Old 10-16-2009, 12:23 AM   #7
newbie
Default brick mold?
the true Bm is as such for stucco with a V shape key to lock down the edge of stucco, but the true brick mold will have the detail on the face and a square 90 deg. on it's outside edge for the ext finish to but. Sears and Amazon carry vinyl sideing components though, maybe something close to get her done!!!
elkwd7 is offline   Reply With Quote
More On This Topic
Hi! I’m Rob McMahon for Expert Village. You can use your table saw for dadoes. If you don’t have a dado blade, there’s another easy way to do it. We’ve got 1 X 4 stock here that we’re just going to use for an example. We... Read More »
Circular Saw Dado Cuts
Circular Saw Dado Cuts by Expert Village
In this clip we're going to continue cutting our dado with our circular saw. I've already preset the base plate at the correct depth, so again, retracting the safety guard manually, I'm now going to follow this line--let me clean up this line a little... Read More »
Hi! I’m Rob McMahon for Expert Village. We’ll get rid of the rest of that. We'll use the vacuum for dust. There you have a ¾ inch ripped dado. It’s nice and snug. It’s a pretty fine cut there because I was moving the fence... Read More »
In this clip we're going to complete our dado cut with our circular saw. Again retracting the safety manually. We're going to remove the remaining waste from the dado. And as you can see now we have a completed groove, and we can drop our shelf in and... Read More »
We are talking about vehicle graphics and the best way to apply them. In this section we will also go over a little bit more about how to put vinyl around the curves. First of all you want to make sure especially in the rear way that you have no dirt... Read More »
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 08:41 AM
Sealing historic brick tenzo General Discussion 2 11-22-2008 05:04 PM
20 year old Brick Wall Repair Bobrobert General Discussion 14 06-04-2008 04:43 AM
Brick up against sliding patio door with J Channel? sandyman720 Building & Construction 2 09-28-2007 09:47 AM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 09:17 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
