Brick Ledge When Using Cinder Block - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-11-2008, 02:02 PM   #1
Brick Ledge when using cinder block
Can someone explain to me how to design foundation using 8" x 16" block and brick faced with 2 x 6 walls. I am laying out my house but it looks like I would need a 10" wall (4" brick ledge and then 6" for sill plate) instead of the 8" wide typical block? In this case is a 10" block used for the foundation and then 6" block to create a ledge? Using an 8" block would cause the sill plate to only rest on 4" with a 4" ledge. Any help is appreciated.
DaveMo is offline   Reply With Quote
Old 03-11-2008, 07:53 PM   #2
ICF Construction
Generally bearing on floor systems only needs to be 1 3/4", more is nicer to work with. If you are planing on 8" foundation that is fine, you can set the sill in and still have your brick veneer.
Many times we have cleaned up our footing forms (2x6) and used them as the sill plate. It can hang to the inside without any problems, unless it's a full basement and you plan to finish the ceiling, then a 2x4 plate is recommended to allow you to drywall the ceiling without interference.
Chris
Chris Johnson is offline   Reply With Quote
Old 07-12-2011, 10:33 PM   #3
8 inch cinder block
can i go with bricks now on an 8 inch cinder block with a 2x4 wall?
adam1979 is offline   Reply With Quote
Old 07-12-2011, 10:40 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
How many people are going to ask questions in this single thread? This is going to get crazy if the second guy doesn't start his own thread.
Adam why don't you stay with the same basic thread you have already started and keep everything together?
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
concretemasonry (07-12-2011)
Old 07-13-2011, 09:58 AM   #5
AGWhitehouse's Avatar
If you want a 6" wall and 4" brick veneer then you will need a 10' foundation minimum. I'd recommend 12" to allow for an air space between the brick and framing. You were correct in saying that you build a 12" block wall up to the brick and then a 6" block wall (at least one course) up to the sill plate.
AGWhitehouse is offline   Reply With Quote
Old 07-13-2011, 10:46 AM   #6
Below is a link to an image of an 8" foundation wall with brick veneer and 4" plate. Wouldn't recommend it because you air space/drainage plane is not adequate (will be filled solid from mortar droppings) and will result in rot over time.
http://www.maconline.org/tech/design...M11DRAWING.jpg
The Following User Says Thank You to AGWhitehouse For This Useful Post:
jomama45 (07-13-2011)
new construction no Brick ledge Justbeck101 Building & Construction 25 11-19-2012 02:03 PM
Cutting cinder block for a large door opening joeyb Building & Construction 2 02-10-2008 01:00 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Requirements for doorway in Brick and Cinder block sandyman720 Building & Construction 5 03-07-2007 10:48 PM
