#1 |
Brick a house
I have a small house I rent that I would like brick. It is on a slab, but the slab doesn't extend any more than what is built onto it now. The exterior is mostly masonite (lap siding). It is 2 story, so I may only be able to brick so far and then have to finish with vinyl siding.
How do you brick an existing house? -Matthew |
#2 |
Brick a house
You can use either thin brick over stucco, pour a brickledge, or attach an angle to the foundation.
#3 | |
Brick a houseQuote:
I would like something as soundproof and secure as I can get, sounds like pouring a brickledge is what I need.. I don't know what attach an angle to the foundation' means.. How deep/wide? How do you secure the bricks to the wall? Do I remove the masonite first? Do I need to add a housewrap first? Thanks -Matthew |
| Display Modes | |
| Cape Cod Style House Attic/Crawl Space Insulation Help | Danielg | Insulation | 24 | 05-21-2012 09:20 AM |
| Brick face house clean up - improvement | jovo14 | Building & Construction | 1 | 08-09-2007 04:40 PM |
| Power Washing Brick House | bobo | Building & Construction | 3 | 09-24-2006 06:53 PM |
| Brick and block house footer question. | ourzoo | Building & Construction | 2 | 07-01-2006 03:57 PM |
| Exterior brick wall has cracks and moves...is this a huge problem? | ConstantChange | Building & Construction | 3 | 06-16-2006 10:09 AM |
