-   -   Brick Home - brick fronts cracking off (http://www.diychatroom.com/f19/brick-home-brick-fronts-cracking-off-52662/)
AndrewF 09-09-2009 11:02 PM
I have a brick home that was built in 1977.
On the SouthWest side of the house, the bricks are cracking the fronts off of themselves.
Someone indicated I should seal the bricks to keep it from getting worse with the freeze thaw cycle we have out here.
If this is indeed a remedy, what type of product should I use?
I will post photos tomorrow when I can take them in the sunlight.
stuart45 09-10-2009 07:01 AM
This is quite a common problem where I live if frost resistant bricks were not used. The problem is worse now as most homes are insulated and heat from inside can't dry them. Also hard cement mortars rather than lime are used, the lime joints allowed water to evaporate through them. If you are going to seal the brickwork I would use a siloxane based sealer, which is said to allow the brickwork to breathe, rather than trapping moisture.
NJ Brickie 09-10-2009 04:48 PM
You need to find the source of your problem first. Why is there that much moisture in the wall? Why is the moisture not leaving the wall through other means (flashing/weep holes)? Post your pictures and you might get some answers.
