Brick Haze On Brick Over Slab Patio - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-08-2008, 11:45 AM   #16
Rewards Points: 1,232
You can try the white scum remover, but you have burned the brick, so there is not much you can do about it.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 09-08-2008, 12:06 PM   #17
What does "burned the brick" mean?
I used the same muriatic solution on the adjoining brick walls to remove a few splatters of mortar which it did and did no damage to the brick. So what does burned the brick mean. And thanks for your help.
joeconroy is offline   Reply With Quote
Old 09-08-2008, 12:44 PM   #18
It is easier to burn brick on a horizontal surface than a wall. It means the brick have been chemically altered, and thus can not be returned to their original state.
Tags
brick haze , bricks , cleaning brick
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 12:17 PM
Brick up against sliding patio door with J Channel? sandyman720 Building & Construction 2 09-28-2007 07:47 AM
Brick Patio - leveling Patcho Landscaping & Lawn Care 1 04-24-2007 01:43 PM
pouring slab for patio bobo Building & Construction 4 02-21-2007 08:30 PM
Steps on an umortated brick patio schott_robert Building & Construction 2 12-04-2006 07:15 AM
