Brick Foundation Wall Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-15-2010, 12:41 PM   #1
I have an older house with a brick foundation. Sometime it was reinforced by sistering some concrete to it, which I guess is pretty standard. It seems to be holding up pretty well. The problem, relatively minor I think at least, is a problem above the sistered reinforcement where there is still just the brick above ground.
Last year I used an auto sprinkler which sprayed on this particular part of the foundation. I believe that to be the reason that for the first time I have ever seen, some blistering in this wall. It seems for aesthetics, the interior brick was covered with plaster, and then painted. It seems like it is this plaster that is blistering out in parts, which I have since removed the problematic areas. The rest seems fine.
Can I/should I just smear some plaster on the areas where there was the problem and paint over it? Since I have stopped using the auto sprinker, I noticed the problem seemed to have stopped getting worse, so I am thinking that stopped, I won't have the problem in the future.
Thanks in advance for any help!
2031pratt is offline   Reply With Quote
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
Ok to insulate the top of hollow concrete brick foundation wall? creamaster Building & Construction 3 10-28-2009 08:43 PM
another brick veneer problem question rdk4609 Building & Construction 6 06-12-2009 09:46 AM
How important is plastic vapor barrier on foundation wall? slatergrl Remodeling 5 02-18-2008 12:49 PM
