Brick Foundation Leak - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-15-2011, 09:05 PM   #1
brick foundation leak
Trying to stop a leak in a brick foundation wall red brick. The water is coming in through the mortar of these bricks. Tried a concrete product to try and seal this from the inside. My next step is to maybe put in a drain tile system from the inside perimeter. This is a older home. After trying to eliminate moisture issue, water seemed to be diverted and still leaking?
STEVE SCHROEDER is offline   Reply With Quote
Old 02-15-2011, 09:17 PM   #2
Rewards Points: 978
you need to find source of the leak/where its coming from. do you know the answer to that?
federer is offline   Reply With Quote
Replacing brick foundation wall bigdog54 Building & Construction 1 12-02-2010 05:41 AM
Brick Foundation Wall Question 2031pratt Building & Construction 0 08-15-2010 12:41 PM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
? RE:Replacing exterior brick with LP lap siding on a poured concrete foundation Greg D Building & Construction 0 11-26-2009 07:49 PM
Ok to insulate the top of hollow concrete brick foundation wall? creamaster Building & Construction 3 10-28-2009 08:43 PM
