Brick Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-16-2010, 11:07 PM   #1
DMD
Brick Foundation
How stable is a brick foundation? Is there repair that can be done?
DMD is offline   Reply With Quote
Old 02-17-2010, 05:51 AM   #2
Too Short? Cut it Again!
Would you please click on your username and update your basic geographic location? It could make a difference in how people respond.
Brick has been used for centuries for foundations and structures. It does need care and feeding though. You should call in an experienced and qualified mason to look at your situation if you suspect the brick or its tuckpointing is failing.
If you are in earthquake country? You probably do not want your house sitting on a mortar foundation of any kind. Replace it if you possibly can.
I would have to look it up but I think the strongest (not necessarily the most damaging) earthquake in US history happened along the New Madras fault in the Midwest. 1811? The Mississippi River flowed backward. Anything near with a brick foundation would have been rubble. All near now when it does its thing, and it has to at some point, will be. Same with all the brick construction along the Hayward fault in N California. It is the most dangerous fault line out there and runs right through Hayward, Oakland, Bezerkeley, Bezerkeley Hills....
Old 02-17-2010, 08:02 AM   #3
DMD
Brick
Thank you. The house is in Iowa. I will try to put in my location. I don't really know how to navigate this site well, but I will try.
Old 02-17-2010, 08:22 AM   #4
are you saying the brick sits on the ground? is the brick several layers wide(not tall)? is this holding up the builing?
The older I get the better I was
Old 02-17-2010, 08:25 AM   #5
DMD
Brick
Yes, this is the 1874 house with the roof issue.
Old 02-17-2010, 08:27 AM   #6
DMD
Brick
The bricks are wide and appear to be in good position.
Old 02-17-2010, 08:39 AM   #7
I have been involved with several brick builing restorations on old farms in va. where the multiple layer thick brick was the foundation/walls all the way to the roof. In those cases we started by underpinning the brick where it met the dirt, quite a process but these buildings have been around as long as yours and more and were weatherring fine. I would suggest underpinning if you can invest in that. are you experiencing failure of some kind?
Old 02-17-2010, 08:51 AM   #8
DMD
Brick
No, this house is on an acreage we plan to buy. We are trying to decide if it is worth putting work into the house. I would like to save the house if we can. It needs a new roof and siding. It has a partial basement where the furnace and water heater are located. We have estimated that the house needs $40,000 to do the work it needs, but since we are only paying the price of the land anyway, it may be worth putting the money into it and use as our primary residence. A contractor will look at it, but it is good to get several opinions.
Old 02-17-2010, 08:52 AM   #9
DMD
Brick
? RE:Replacing exterior brick with LP lap siding on a poured concrete foundation Greg D Building & Construction 0 11-26-2009 07:49 PM
Ok to insulate the top of hollow concrete brick foundation wall? creamaster Building & Construction 3 10-28-2009 08:43 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Sealing historic brick tenzo General DIY Discussions 2 11-22-2008 03:04 PM
brick foundation walls drummerjim Building & Construction 5 01-23-2008 05:23 AM
