Brick Fell From My Chimney Exterior Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-13-2011, 08:14 PM   #1
brick fell from my chimney exterior wall
What can I use to "glue" it back?
thanks
what-do-i-do is offline   Reply With Quote
Old 09-13-2011, 08:36 PM   #2
Rewards Points: 558
Did the brick split or completely fall out?
epson is offline   Reply With Quote
Old 09-13-2011, 08:46 PM   #3
ashkanr's Avatar
thanks
Carefully examine the mortar in between all the bricks of the chimney. The mortar might be eroded by elements and the chimney might be very unstable; kept in place only by the weight of the bricks.
Be careful!
ashkanr is offline   Reply With Quote
Old 09-13-2011, 08:48 PM   #4
Rewards Points: 558
Unfortunately you will need to chip the brick out and all the mortar around it and place new mortar on the brick below it and on top of it and set a new brick in place. Then fill in mortar around it and you can use your finger to remake the joint around it if you donít have a tuckpoint tool.
Old 09-14-2011, 09:13 AM   #5
I will check the rest of the bricks and call in a pro if more are loose. Otherwise I will get some mortar at HD
Thanks!
Old 09-14-2011, 10:53 AM   #6
Rewards Points: 6,652
http://www.google.com/search?hl=en&s...3.8.5.2.1l19l0
Old 09-14-2011, 01:45 PM   #7
Rewards Points: 5,336
One brick rarely fails by itself. Do a careful examination of the chimney above the roof line. This is where the structure wears the most.
Also check the chimney cap.
Ron
B. Franklin 1759
water leaking through brick chimney quigleybmd Concrete, Stone & Masonry 45 02-26-2013 04:26 PM
Brick work to repair a Chimney worthspending Building & Construction 2 10-17-2010 07:58 AM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
Any good brick chimney water repellents? quigleybmd Roofing/Siding 3 04-12-2010 06:19 PM
Addition around existing brick chimney Adenmoor Building & Construction 2 11-20-2004 10:37 PM
