Brick Exterior Facelift - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-09-2008, 06:26 PM   #1
I have a 17yr old brick house. It looks as though there was paint on the bricks to make it gray/white etc. It is wearing off and looks like the bricks were a redish color which now looks pretty bad. Is it possible to repaint or possibly use concrete/masonry stain to update the look?
mcorn is offline   Reply With Quote
Old 04-09-2008, 08:20 PM   #2
remodeling pro
It can be repainted. Go to a local paint store, real paint store like SW or BM, not HD or Lowes, and ask for advice. The basics are a good washing, wire brush off any loose or scaling paint, and spot prime. Depending on how badly the old paint is chalking, they may recommend a complete priming with a bonding primer. As has been posted many times, even a contractor grade product from them will be superior to the so called "premium" paints from the big boxes. Also a good time to chip away the most likely cracked and failing old caulk at doors and windows and redo with a quality sealant, as oppossed to just smearing a wider bead of latex over the old stuff.
troubleseeker is offline   Reply With Quote
Old 04-10-2008, 10:32 AM   #3
Thanks, I will do that. I had even given thought to a power wash and masonry stain to change the color to a tanish/brown. Would that be an option as well?
water leaking through brick chimney quigleybmd Concrete, Stone & Masonry 45 02-26-2013 04:26 PM
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 03:07 PM
Bad Brick Mortar ??? kourso Building & Construction 21 11-08-2010 12:11 AM
Cheaper masonry alternatives to brick? Jemo Building & Construction 9 05-18-2007 12:31 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
