Brick Driveway Gate Posts - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-14-2010, 10:42 PM   #1
Question
I'd like to know what the proper procedure is to make an adequate concrete base for brick pillars that need to support 6X10 ft. driveway ornamental gates
intranserv is offline   Reply With Quote
Old 03-14-2010, 10:49 PM   #2
Learning by Doing
Leah Frances's Avatar
Bump - cause I want to hear the advice you get.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-15-2010, 12:32 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,612
Ayuh,... Where do you live,..?? Is Frost a problem,..?? That'll determine the depth...
Old 03-15-2010, 12:57 AM   #4
Contractor
Brickie's Avatar
Rewards Points: 79
Excavate, form & pour
Northwest Indiana Masonry
http://www.nwindianamasonry.com
Brickie is offline   Reply With Quote
Old 09-20-2010, 07:39 PM   #5
Question
Gate pillars
I live in the Edmonton area which is Northern Alberta Canada & frost is definitely a problem here. What I've done so far using my own knowledge is: I augered 2- 12" holes, 6 ft deep & I plan on cementing these next weekend. I've welded 2 columns 6' tall with 4- 11" circles 1' apart & three 6' uprights that I plan on dropping into the holes before I pour. I also plan to incorporate (in the same pour) an elevated (by about 2" from ground level to prevent heaving) 20" X 20" X 3 1/2" reinforced slab on top to lay my bricks on. Is that the proper procedure? Do I need to have more rebar tied in to reinforce the middle cavity that I fill as I go up? Also, what do I do about the gate hinges that need to protrude out of the brickwork as well as a suitable anchor for future automatic gate closers. I'm a welder, so fabricating nessecary bracketry is not a problem. Note: my gates are steel construction ( 2 guys can handle one comfortably about 200 lbs.). What are your thoughts? I just remember, I also need power to be able to run the closers & a light & plug (which I can run later) but I guess I have to put conduit in the column too!
plans for a traditional driveway gate David267 Carpentry 2 09-18-2009 09:34 PM
Driveway Gate Construction Questions KP Texan Building & Construction 3 07-30-2009 08:45 PM
Craftsmen style driveway gate bigb6456 Carpentry 12 05-19-2009 12:02 PM
Driveway Gate - swing open -vs- slide sideways MrLinux General DIY Discussions 1 10-30-2008 03:13 PM
Brick pavers on driveway ???? sflamedic General DIY Discussions 2 04-21-2008 11:12 AM
