Brick Chimney On The Side Of A Brick House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-22-2011, 05:01 PM   #1
kmw
brick chimney on the side of a brick house
the chimney is leaking. how should the flashing be installed down the side of the brick
kmw is offline   Reply With Quote
Old 04-22-2011, 06:34 PM   #2
Rewards Points: 582
Have you got a photo?
stuart45 is offline   Reply With Quote
Old 04-22-2011, 06:53 PM   #3
Leaking through the flue opening, or are there cracks in the mortar and/or liner?
jane99 is offline   Reply With Quote
Old 04-22-2011, 07:08 PM   #4
Rewards Points: 5,336
It should be counter flashed. "L" shaped flashing under the shingles and up the brick and top flashing bedded in the chimney mortar down over the shingle molding.
Chimneys can leak a number of other ways, though.
Ron
wet chimney inside the house... sobro Roofing/Siding 3 04-14-2011 05:03 PM
House 2 years, 5 months old now has huge bulge on side of house. Dee Johnson Building & Construction 16 10-09-2010 08:28 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
Addition around existing brick chimney Adenmoor Building & Construction 2 11-20-2004 11:37 PM
